Show messages: All
1
2-5
Hi Billabong, it can be difficult to remove a hard edge right in the middle of other stuff like that.
Other than filleting, if you can trim away some space around the hard edge then the Construct > Blend command can put in a smooth connecting surface between the open edges. Or the other main approach is making a larger single surface across areas that are supposed to be smooth instead of filling things in piece by piece.
Thanks Michael. I was afraid of that. I'll try your suggestions. Thanks again.
-B
Hi Billabong, here is a version with those hard edges removed.
It's a pretty tricky process though, it's better to prepare it earlier in the model construction.
I set up a blend surface like this:
And then the tricky part is getting it in place, which involves untrimming and retrimming surrounding pieces.
Drone_new_v04_2.3dm
Thanks so much Michael!
Show messages: All
1
2-5
