Full Version: Filets
Hi, is there an easy way to make this kind of profil, a command like the one for filet? I often do that with to circle and loft or boolean diff, but it's tedious.
Paquicinno
Conge.3dm
Hi Paquicinno, there is an "inverse fillet" plug-in here, is it close to what you want? :
http://moi3d.com/forum/index.php?webtag=MOI&msg=10340.2
Hi Michael, thank you for your respons. The script doesn't what i want to achive. Beside, it 'd be great to work like fillet, by selecting curves on a solid, then create the "inverse fillet".
It is a common moulding in woodworking.
Hi Paquicinno,
Unfortunately, filleting edges of a solid is a very complex operation, it would be very difficult to make a script that tried to do it that way.
I've attached a modified version of InverseFillet which has the circle position how you want.
InverseFillet2.zip
Hi Michael, thank you for the script, that will do.
Paquicinno
