Hello. Thank you for your help.
By editing SidePane.htm, Construct and Transform were separated.
Also, by introducing CustomUI and moving the four command buttons hide, lock, history, and align
I now have enough space (height) to deploy even on a 1920x1080 monitor.
This allowed me to expand and display all tabs as shown below.
This is an ideal situation for me, very easy to use.
However.... For some reason, the Transform and Dim tabs remain folded on startup.
How do I make them open on startup?
MoI version4, windows7, 1920x1080 monitor
marzRX
Hi marzRX, it's probably collapsing because there isn't room for it in the unmaximized window.
Try unmaximizing the MoI window and then size the unmaximized window to be large, exit MoI, then on the next run you can maximize it and leave it maximized.
Thank you! Thank you so much.
I'm so happy.
I do a lot of modeling with MoI3D. ;)
marzRX
