16-24
Ok. Thanks.
Pity!
Ciao :)
Complete French Tutorial AutoHotPie / Moi3D
Final Moi3D-AutoPie in English! The French one in few times!
https://moiscript.weebly.com/autohotpie.html
I have used the mode 4! Free to you to take another one! ;)
Mode 4
English version is working fine! :)
some Scripts included! (not shown here)
https://moiscriptlweebly.com/autohotpie.html
English & French version done! :)
Only one shortCut to remember! "X" ;)
https://moiscript.weebly.com/autohotpie.html (Bottom page)
Nice! I am not speaking French, so must be missing some details. I have everything installed and can create my own menus, but not sure how to install the pie menu you created.
edit:
nvm, I found that you need to "import settings" in Autohotpie and direct this to the AHPSettings.json that you have so kindly provided. This will load your pie menus, which can then be modified as the user wants.
Awesome! Thanks again for your wonderful contribution.
Tell me if that is working fine for you! (the English version! ;)
Don't forget to add the 2 files (commands & scripts) if you want all that is in Pies!
And remember Launch AutoHotPie
then green Button Save & Run (always in AutoHotPie)
Then launch Moi3D
then "X" if you want call AutoHotPie inside Moi3D
Esc for normal mode, "X" again for recall it in the same session etc...
yeah, all that works.
Just some instructions missing, likely because you built the script and didnt need to follow those steps, but if a user downloads your content, they have to follow additional steps.
After installing:
1. import settings file that you provided (this will delete any previous settings and menus)
2. import custom icons through Autohotpie GUI (drag and drop wont work)
Cool and thanks for the complement of infos!
16-24
