good evening.
some one has an idea why i cant blend these 2 edges. loft is working fine but somehow they dont blend.
thanks!
without the complete 2 pieces (3dm) that is some hard to answer! ;)
Hi Edwin, I see the edit frame is showing on one of the edges. That likely means that you don't actually have an edge selected there, you've got a separate curve object selected there that is right on top of the edge.
Hide or delete the separate curve object so that you can select the edge.
For something like a cylinder, select the "upper" round edge of the rounded part of the cylinder, not the edge of the planar circular top (if any), which would close the cylinder.
hi michael.
yes, it was exactly like you said. had the curve selected and when i used both edges it worked fine.
thanks a lot!
