4-23
24-29
Maybe right click on the Edit > Trim button would be a good place I could put this one in the regular build.
I can dig it….
Christmas was one month ago! :)
And the cool thing is that works in 3D!!!
Maybe with unexpected result! :)
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/gif_unexpectable.gif
French Version :)
https://moiscript.weebly.com/quicktrim.html
Curiously don't work for the 3 bottom external curves (video) ? (bug or don't work on yet trimed curves or...?)
It's intended to be used on 2D curves. But can you please post the .3dm file for the model you show though, are you certain that the curves intersect each other?
But in general I would recommend using it on 2D curves and not on 3D curves.
It's because regular Edit > Trim is not focused on completely deleting entire curves, it's focused on deleting a portion of a curve. So with regular Trim if there is an intersection only at one end of the curve it won't be targeted. QuickTrim then inherits that same behavior from regular Trim.
Maybe I can get it set up so that QuickTrim will work for that case though.
No problem i had saved it in case of! :)
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/unexpectable_result.3dm
The concept and video are great, but, on my M1 Mac Studio it acts a little kooky. After swiping across the curve to trim away I get a 'beachball' for maybe 15 seconds and then every intersecting line on the entire model is 'broken' by inserting a point at the intersection- another 10 or 15 seconds and the section I wanted trimmed is gone. So, the curse of the Mac strikes again. I wish I could capture the model at the point where all of the intersecting lines are broken into separate segments and just run around the model deleting all of the segments I want to trim, but I can't do anything once the beachball and point insertion process starts.
It's so close to amazing- if I could forget about swiping and get MOI to temporarily insert a point that breaks every line at an intersection I could delete the offending line segments in no time.
Again, it's so close to being a technical illustrator's dream function. In case you don't have a silicon Mac I can make a screenshot of the intermediate step, where points are inserted at every intersection throughout the entire model.
Thanks for the effort,
Rick
This is what I see after swiping across 1 line segment- it does delete the segment. I would like to work on the drawing at this stage- it would be so easy to just move around deleting the bad segments.
Hi Rick,
Have you tried out the Virtual Segment Delete tool in CorelDraw?
https://www.youtube.com/watch?v=3nwKVFKy-4Q
Also, I've had good luck with the Hatchet plugin for Illustrator when I need more control than virtual segment delete
https://rj-graffix.com/product/cutting-tools-plugin/
Peer,
Thanks for the suggestions, I haven't used CorelDraw this century- didn't know it was still around, but that tool looks really useful. I've had mixed results with third party Illustrator plugins- not working over OS upgrades, Adobe updates, etc- I'm trying to like Affinity Designer, but it's not going well- just selecting a curve is too hard, and no LivePaint makes it too time consuming to use.
I really like 2D drawing and editing in MOI, so I export to illustration apps as a last resort. If/when MOI can make trimming faster I'd do 99% of a drawing in MOI.
Calling a Trim command and having it trim a selected line to intersections without clicking the cutting line and the segment to be deleted would be ideal, maybe with the option to delete or keep the new segment.
For me, bouncing back and forth between programs with all of the translations involved is slower than just struggling through- maybe Michael will come up with a solution.
Rick
“””””” So with regular Trim if there is an intersection only at one end of the curve it won't be targeted. QuickTrim then inherits that same behavior from regular Trim.
Maybe I can get it set up so that QuickTrim will work for that case though.””””””
That seems like the behavior i’d expect from your ”Eraser” tool once you get click and drag implemented.
Thanks, that was a bug where the "curve from 2 views" mechanism in the Intersect command was causing some 3D curves to be targeted by a swipe when they shouldn't be.
I've uploaded a fixed version, this one should now ignore this case instead of mistakenly targeting 3D curves.
Thanks, - Michael
Hi Rick,
This likely has more to do with your particular model than being on Mac, can you please send the file to me at
moi@moi3d.com so I can test with it?
One problem that I just fixed now is that it was trying to process hidden curves instead of skipping them.
Also I've updated it so that it only tries to intersect curves that are on the same plane as the swipe, that should help with performance.
Thanks, - Michael
Cool!
But seems this is not the same behaviour of the Trimer...
Now it is like a Polyline and not a curve!
Does this normal ?
> Does this normal ?
Turn off grid snap in the bottom toolbar.
@Rick - thanks for sending the file through e-mail.
So just so others see this as well the slowdown issue is trying to use QuickTrim directly on your model with 3296 curves.
That will do the equivalent of using the regular Trim command and selecting all 3296 curves as both the objects to be cut and also as the cutting objects.
To solve this you'll need to narrow down the number of candidates that QuickTrim will be trying to process.
You can do that either by hiding curves outside of a current active working area of say a few hundred curves or by selecting curves in a particular area. If you have some selected curves the cutting up processing will only happen on that selection.
Maybe someday I can work on this to make a large several thousand candidate pool work better but that won't be anytime soon. To use it effectively you will need to narrow it down to something like 2 or 3 hundred curves or ideally even less rather than several thousand all being active on the same operation.
Thanks, - Michael
Ok!
And the Trimer works only on curves and not on Lines ?
It works on lInes, but only if the line is being cut up into some pieces. It currently won't remove a line where the line only touches other things at its endpoints instead of being cut somewhere inside the line.
It will be able to do that in the next v5 beta release, it needs an adjustment in the Trim command factory to also target those cases.
Thx for the Infos!
4-23
24-29
