Show messages: All
1
2-3
Hi Matadem, you can use the Construct > Offset command to do that.
Select the curve
Run Construct > Offset.
Set mode to "By Distance".
Put in 1mm in the Distance field.
Pick point to the side you want to offset.
Looks like this:
Got it...I tried it for some reason it would not go.
But it works and I can move forward.
Thank you!
Show messages: All
1
2-3
