Show messages: All
1-8
9-18
I've test with increased break angle, but if was possible will great if the command take the existing CV points to make a curve.
Below and image where the black is the source polyline , the green is manually done by creating a CV curve snapping on every CV point of the polyline and the last is obtained via Rebuild command with 180° breaking angle, but is what I want.
Hi pafurijaz, the "Endpoints" mode is meant to be used on a polyline that is trying to resemble a smooth curve with a denser set of points than what you show in your example.
I guess there could be an option added for whether to make a curve by interpolation or by using the points as the control polygon of the curve.
I'm not quite sure what to label it though.
I really hope you can do it, for me this option could solve some problems I face when working with polygonal models of hulls.
I have the label... "Control Polygon" or maybe "CV points"
Hi pafurijaz,
Yes the option would be a dropdown that could have "Interpolate" or "Control points" as the 2 options in the dropdown.
The label part that I'm not sure about is what to put as the label in front of the dropdown, like where it says "Mode:" in the rebuild options currently.
I see that rebuild curve is the more flexible tool.
But when I use pipe2 after, it doesn´t work. It´s the only case I need to reconstruct curve. Can you tell me why?
Koi
I don't see problem...to Pipe2 after a rebuilded curve...
Hi Koi,
It's difficult to know why without being able to examine the curve. Please post the .3dm model file with the curve in it.
Hi pafurijaz, I figured out calling it "Points: Interpolate" or "Points: CVs" doesn't take up too much space.
I've got an option for that set up for the next beta.
Thanks, - Michael
Awesome..
hi frenchy pilou and Michael,
thanks for your answers! You confused me, that it is possible.. So I tired again, and it works. I can´t tell you what I did wrong.
I´m sorry for taking your time for that.
Koi
Show messages: All
1-8
9-18
