Show messages: All
1
2-3
Hi Lestatdelc, that's just a display artifact that should be ignored.
There is a setting under Options > View > Meshing parameters > "Mesh angle" that you can tighten up to reduce it but I don't recommend that because it will greatly increase mesh density in other areas and can bog things down when you have larger models.
More information here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10580.2
Once again you demonstrate why I love using this application. The quick, and responsive reply to a user issue.
Thank you.
p.s. while it was a display artifact it was actually causing some objects to get "lost" in the "faceted" surface.
Show messages: All
1
2-3
