Show messages: All
1-7
8-16
I believe if you make "box modeling" + subdivision (Max Smirnov) inside Moi, you will have automatically quads inside c4...
Quads like this ... that makes difference than regular quads ? I don't know :)
If you limit "Ratio Aspect to 1" at the export OBJ you will have this! So real quads! ;)
Not regular like classical...but what difference for the Render engine ? ;)
For polymesh in C4D I don't know again if that is satisfying !
Just try it! :)
I suppose that you have seen this another free one ?
https://github.com/huxingyi/autoremesher (not tested)
Thank you very much Pilou !
It seems that InstantMeshes does not like Ngons and
Autoremesher makes troubles, too ? I will go trying ...
Take just triangles maybe for the quads transformers!
There is also a free one that makes quadrangles! : Meshlab!
some alambicus but...
https://www.meshlab.net
And you can also send me your file for test inside ZBrush or 3D coat...they have remesher inside! ;)
I have not c4d!
Thank you Pilou for the tip - downloading .
>>And you can also send me your file <<
If I really encounter a huge problem, I will come back to your kind offer, Pilou - thank you.
Monsieur Pilou, may I ask you for links to your great tips and tutorials about Subnurbs-modelling in MOI ?
maybe there
https://moi3d.com/forum/index.php?webtag=MOI&msg=9689.1
The one of today :)
When some faces on a solid are not divided for general subdivision so fails
Draw lines missing
Select All / Trim
Kill Curves (Browser curves selection)
Subdivide
Fantastic and thank you very much !
Show messages: All
1-7
8-16
