Show messages: All
1-7
8-14
Hi Viewbyte,
> Because in the method / demo I uploaded I'm not snapping to anything. Snapping is not active at all.
Yes, but that's the problem - that would be unusual in Moi to have something target a point on an object but not be able to use snapping while doing so.
But if I do a pan, zoom or rotate in MOI now - I'm not typically 'targeting or selecting' anything, so why are you suggesting that's a requirement with an alternative (improved) method?
Hi Viewbyte, the difference is that pan/zoom/rotate like you're describing manipulates the camera and doesn't do any object-specific targeting in it.
The method that you were describing targets an object but in MoI when you target a point on an object with the mouse it should allow for object snaps.
I would say the method I'm describing targets a location in 3D space - to manipulate the camera : )
Hi Viewbyte, it's a location in space on an object. In MoI it's a focus for points on objects to be placed with precision using object snaps.
"In MoI it's a focus for points on objects to be placed with precision using object snaps."
I totally understand and appreciate that, but I'm not doing, or intending to do, anything whatsoever to the object by manipulating the camera.
Anyway I'll rest my case here. I appreciate your engagement and willingness to respond, and I do understand the desire to stay consistent with your chosen modus operandi. MOI is clearly a very fluid and well thought out application. I just feel the viewport navigation isn't quite on that same high level.
I've found a script on Petr's page that goes most of the way to what I want when assigned to a shortcut:
script:var objs = moi.geometryDatabase.getSelectedObjects(); if ( objs.length > 0 ) { moi.ui.mainWindow.viewpanel.getViewport('3D').targetPt = objs.getBoundingBox().center; }
It requires a section and a shortcut key press - but I can live with that.
Show messages: All
1-7
8-14
