Show messages: All
1
2-5
Hi RIL, try this:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10063.3
or this one:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9439.13
Yup, that did the trick.
Unfortunately only three tabs can be open at the same time on a 1920x1200 screen.
Perhaps it is possible to shrink the panels a bit, or lock them open (even if the lowest one then can slide out of screen, but then I can chose myself which other panel I would close to the the lowest one back in view again, aso). Now it just forcefully closes the lowest tab.
Edit: I tried also the jf-script in the *first link*, but that one allows only one of the two lowest panes to be open at the same time, either Construct or transform, so that one doesn't make any difference really.
// RIL
Hi RIL, it is possible to shrink the panels (and all of the UI) down a little bit by using Options > General > "UI size". Move the slider a little to the left and all the UI will shrink down.
Yes, it's intentionally designed to behave like that. Trying to make an individually lockable setup would be pretty complicated.
Perfect! Moreover, if first shrinking until enough panels show, then one can increase again and they stay expanded.
Thanks!
// RIL
Show messages: All
1
2-5
