Show messages: All
1-2
3-11
Ah yes forgotten this one! :)
Else surely Elephant can do something!
Thanks Burr! To do it along a path, make it along a horizontal line first and then apply it to the path using Transform > Deform > Flow.
That's perfect! Many thanks!
Salvatore
Are you sure this "Shift Array" still work on V4? I tried different times without results...
Salvatore
Hi Salvatore,
I just tested it and it's working ok for me over here in v4. Are you following the instructions to include a point object with each array instance?
Yes works fine in V 4.0 ;)
Draw some Objects + a point at the same place/object for a regular result : with the Array / Dir for example...
Deselect all
call the plugin
Select all (objects + points)
Click Start - End first Step (here 2 unities) so gap result will be here 2 4 6 8
et voilĂ :)
Ok, it seems to work now... The only issue I found is that it only works once. So if after getting the result from shiftarray I undo the command I cannot repeat shiftarray unless I do a new array. Is that normal?
S
No! Seems a bug! :)
So UNDO to the start objet + point then Array DIr Select All call the Plug SHift Array etc...
Hey S.....
http://moi3d.com/forum/lmessages.php?webtag=MOI&msg=5595.9
Show messages: All
1-2
3-11
