I zoomed in to the microscopic level on my model and indeed it's not tangent. Then I tried the Jfs (PAQUICINNO) method in his video (which I think is the better solution), and it also was not tangent. Of course these are visual checks.
I don't know the mathematical solution, or even if displayed curves are 100% visually accurate when zoomed in that far.
Practically speaking, the error I saw when zoomed in that far is below the resolution on my micrometer :)
But it would be nice to verify what the precise solution is.
Update - I see Michael has linked to a solution above. Who wants to test it? :)
I was suspicious about your solution. and yes I think PAQUICINNO's method works better maybe! ( yet it needs to be proved mathematically)
And I checked something when there is a line tangent to a circle and when you zoom in on atomic scale you see that there is a tiny gap between tangent line and the circle - which I believe it is normal to see such thing at such microscopic zooms - but there are no several crossings!
And feel free to check what I said in the attached file.
Hello guys, I have crossed upon new problem! You might be able to help :)
I tried to create Tangent curve to red line at Point_1 and the green circle.
( I know the center of the circle which is tangent to red line at Point_1 would fall on the Magenta line)
I was able to draw Blue curve using "Arc Tan" but it was by try and error method I have also tried to use Martin's method but in this problem because the blue curve should be tangent to red line at Point_1 I faced difficulties using Martin's method.
So I have a problem with Martins video. Looking for some help.
I must be misinterpreting a click or a drag.
I make the line and 2 circles. Then offset the line the distance of circles.
Start the tangent circle command and select on first circle.
Second click on line ends command for me. It seems Martins video gets a second point click there, then third pick on second circle is a diameter pick for the tan snap...
