Show messages: All
1-3
4-6
A simple way is :
select your object.
Edit/separate
Select the useless surfaces and delete them.
Select the main surface
Select all edges you want delete
Delete them....
The holes disapears !
And you have your original surface.
Don't forget to select and join the surfaces to have original object.
Dear Pilou,
I found a solution to my particular example :-)
It seems there are few tricks, My problem is solved thanks :-)
Edit:Dear Phiro,
Your trick was so handy and quick! Thank you so much! :-)
Show messages: All
1-3
4-6
