Show messages: All
1
2-6
Best and the more speedy is copy / save somewhere your original!
A tricky tip is to launch any number of Moi sessions in the same time!
so you can make Ctrl + C, Ctrl + V (Copy / Past) of anything to any other sessions!
Thank you for your tip. But imagine I have lost the original Shape then what is/are the best way/s to recreate the original shape out of the altered one?
As I mentioned I tried Swipe & Network which gave me a shape close to Original one but it is still not the one I had started with! I just wanted to know if there is a method to do so.
A simple way is :
select your object.
Edit/separate
Select the useless surfaces and delete them.
Select the main surface
Select all edges you want delete
Delete them....
The holes disapears !
And you have your original surface.
Don't forget to select and join the surfaces to have original object.
Dear Pilou,
I found a solution to my particular example :-)
It seems there are few tricks, My problem is solved thanks :-)
Edit:Dear Phiro,
Your trick was so handy and quick! Thank you so much! :-)
Show messages: All
1
2-6
