Hello guys,
I hope you are doing well, I have got a question for you. I had created shape number 2 out of shape number 1, now my question is how can I get back to shape number 1 ( imagine I lost shape number 1)
I have tried to recreate shape number 1 using outlines of shape number 2 (Yellow lines) I tested Swipe & Network methods which gave me surfaces number 3 & 4 respectively.
My question is that is there a way I could recreate shape number 1 exactly as it was? If yes, What way/s are the best to do so?
You can check the attached file.
How_to_fix_this_2.3dm
Best and the more speedy is copy / save somewhere your original!
A tricky tip is to launch any number of Moi sessions in the same time!
so you can make Ctrl + C, Ctrl + V (Copy / Past) of anything to any other sessions!
Thank you for your tip. But imagine I have lost the original Shape then what is/are the best way/s to recreate the original shape out of the altered one?
As I mentioned I tried Swipe & Network which gave me a shape close to Original one but it is still not the one I had started with! I just wanted to know if there is a method to do so.
A simple way is :
select your object.
Edit/separate
Select the useless surfaces and delete them.
Select the main surface
Select all edges you want delete
Delete them....
The holes disapears !
And you have your original surface.
Don't forget to select and join the surfaces to have original object.
Dear Pilou,
I found a solution to my particular example :-)
It seems there are few tricks, My problem is solved thanks :-)
Edit:Dear Phiro,
Your trick was so handy and quick! Thank you so much! :-)
