Full Version: "Cyber Klaus Meine Cthulhu" (Giger Style)
Show messages:  1-3  4-22
5 May 2021   [#4]
Excellent as usual!
5 May 2021   [#5] In reply to [#3]
Wooow! you are a trickster!
by the way I have an off topic question "u did all the modelings in MOI?"
5 May 2021   [#6] In reply to [#5]
The most modeling I do in MoI3D, in this case I use Cinema4D to pimp the cables with Mograph, the body retopo and Fillets are only MoI3D, in more complex cases I use also Fusion or 123d for fillets sometime.
5 May 2021   [#7] In reply to [#6]
You have a command for cables by Max Smirnov ;)
Wire
http://moi3d.com/forum/index.php?webtag=MOI&msg=8301.20
and a modification y Marco for input any profil!
Wire2
5 May 2021   [#8]
Super-impressive work, Christian, kudos!
May I ask which renderer you've used? Maybe Octane? I'm into Octane lately, using Blender as its host.
6 May 2021   [#9] In reply to [#6]
Tanx for the explanation :)
6 May 2021   [#10] In reply to [#7]
How does that modification works? (How can I use that?)
6 May 2021   [#11] In reply to [#10]
Just unzip and put these files inside the commands folder
http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=e96f49498fe8971448bbf73b80f86141&filename=Wire2.zip
Draw any "one" profil even "curvated" ( closed or not ...if "not" of course your cables will be also "open") , draw any volumes with faces
Run the plugin and follow it
so Select the "Source" Profil
Pick first Point on a face (even a point on the empty space!!! )
Pick second Point on another face (even a point on the empty space!!! )
That all! Have fun wiring! :)
Here points are on the empty space! :)
6 May 2021   [#12]
Body Kitbash Test
6 May 2021   [#13] In reply to [#11]
Tanx :), I did it!
Yet, I have got a question for you. could we have control over the path of the wire?
6 May 2021   [#14] In reply to [#12]
wooow!
How long it took for you to get to this level of mastery? I mean I am trying to create such models you create but it seems my progress is slow! What tips or advice you have for me to make my progress faster?
6 May 2021   [#15] In reply to [#14]
I am create things in MoI3D since aroundabout 2009 or 2010, I think.
6 May 2021   [#16] In reply to [#15]
Ah ok :)
You are so good at it! Amazing! :)
And tanx to Michael :)
6 May 2021   [#17] In reply to [#13]
<< in Moi about wire2 : control of the path of the wire
just a little relative control : by the parameters...but the path itself is just a result of the parameters!
Make sweep if you want more...
6 May 2021   [#18] In reply to [#17]
I admire your models, renders and technical creativity.
Excellent!
Mik
6 May 2021   [#19] In reply to [#17]
I C. Tanx
6 May 2021   [#20] In reply to [#8]
Render used by Zarkow ;)
https://www.artstation.com/artwork/Nx0AQJ
<<Modeled in Moi3D
<<Rendered in Octane for C4D
6 May 2021   [#21] In reply to [#14]
<< What tips or advice
Start with small objects...
7 May 2021   [#22] In reply to [#20]
"Render used by Zarkow ;)
Modeled in Moi3D
Rendered in Octane for C4D"
Thanks Pilou!
Octane, nice.
