2-21
22
Absolutly mind-blowing! Bravo as usual!
Because of you I have an Insta registration! But empty because i have not the new phones of today! :)
Some Renders
"Hello I am the Cyber Cthulhu version of Klaus Meine from the band the Scorpions."
More on Artstation, Twitter or Instagram:
https://www.artstation.com/artwork/Nx0AQJ
https://twitter.com/SchwegerZarkow
https://www.instagram.com/christianschweger/
Excellent as usual!
Wooow! you are a trickster!
by the way I have an off topic question "u did all the modelings in MOI?"
The most modeling I do in MoI3D, in this case I use Cinema4D to pimp the cables with Mograph, the body retopo and Fillets are only MoI3D, in more complex cases I use also Fusion or 123d for fillets sometime.
You have a command for cables by Max Smirnov ;)
Wire
http://moi3d.com/forum/index.php?webtag=MOI&msg=8301.20
and a modification y Marco for input any profil!
Wire2
Super-impressive work, Christian, kudos!
May I ask which renderer you've used? Maybe Octane? I'm into Octane lately, using Blender as its host.
Tanx for the explanation :)
How does that modification works? (How can I use that?)
Just unzip and put these files inside the commands folder
http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=e96f49498fe8971448bbf73b80f86141&filename=Wire2.zip
Draw any "one" profil even "curvated" ( closed or not ...if "not" of course your cables will be also "open") , draw any volumes with faces
Run the plugin and follow it
so Select the "Source" Profil
Pick first Point on a face (even a point on the empty space!!! )
Pick second Point on another face (even a point on the empty space!!! )
That all! Have fun wiring! :)
Here points are on the empty space! :)
Body Kitbash Test
Tanx :), I did it!
Yet, I have got a question for you. could we have control over the path of the wire?
wooow!
How long it took for you to get to this level of mastery? I mean I am trying to create such models you create but it seems my progress is slow! What tips or advice you have for me to make my progress faster?
I am create things in MoI3D since aroundabout 2009 or 2010, I think.
Ah ok :)
You are so good at it! Amazing! :)
And tanx to Michael :)
<< in Moi about wire2 : control of the path of the wire
just a little relative control : by the parameters...but the path itself is just a result of the parameters!
Make sweep if you want more...
I admire your models, renders and technical creativity.
Excellent!
Mik
I C. Tanx
Render used by Zarkow ;)
<<Modeled in Moi3D
<<Rendered in Octane for C4D
<< What tips or advice
Start with small objects...
VIDEO
2-21
22
