15-34
35-49
You can yet use the free 123D Design, or the free online Onshape for the problematic fillets! ;)
Here's hoping! :D
Can we have something like this, please. A quick way to exchange the two values when using the chamfer tool.
Hi 3image,
Update the MoI v4 Chamfer.htm and Chamfer.js (in the install's commands folder) with the attached versions and also put the attached Swap.png inside the install's ui folder.
That should then give you a swap button like this:
Chamfer.htm
Chamfer.js
Very cool! :)
That is so cool, Michael, thank you very much. I've missed something like this for years and finally decided to write a proposal in the forums.
Seems very cool indeed! ;)
'Quite often after creating the object from curves I want to do some operations using edges. And as I have curves in the same area I have to hide curves first. This quickly gets annoying.
In Rhino we get a little pop-up when there are multiple objects in the same place so the user can pick the desired one. That, or some setting which would allow you to define priority (for example edges over curves) would be great.'
Revit has a function where you just hit 'tab' and it cycles through the objects the mouse is hovering over. I miss it in other softwares...Very very handy, quick, and yes far less intrusive than the Rhino pop-up...
- Rich
How can I setup Screenshot upon Save, in the meantime?
Hi Mindset,
I've got filesystem plugins for showing .3dm thumbnails implemented for the next v5 beta, I'll try to get it wrapped up soon.
WOW❗
The menu bar can be customized to add plug-in functions?
Hi feirui445, there is a UI Mod that you can install that adds those buttons:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.268
http://moi3d.com/wiki/MaxScriptArchive
you can click an Add button, the commands folder will be displayed. If you select a plug-in, it will be displayed on the menu
Would love to see MoI get MDI tabs….
15-34
35-49
