> If the overlap option in Acrobat Reader does what you need then that should be the easiest way and a plug-in to export multiple PDFs wouldn't be needed.
I made a couple of tests, overlapping from Acrobat is good enough so I prefer not to waste your precious time with a plug-in,
However, to make the process more paper efficient it would be good when exporting a selection to PDF, to have an option that automatically push the selections to the bottom left corner of the page, like some sort of local origin. Can this be implemented somehow?
There is an option currently to center the output on the page. I don't understand why placing them in the bottom left corner of the page instead of centering would be more paper efficient, can you describe that a little more?
Well, I was thinking, if I have 30 pieces that are all 200-250mm high and vary slightly in length, from let's say 500mm to 800mm. I can select each of them, set a custom paper like 297x 810 and be sure they will all fit in that kind of sheet. If I centre the output, it will be ok for the height since there is no so much difference but I would prefer to see the output pushed to the left so that I can avoid printing the part left white... So actually in that example the best would be more centre-left rather than bottom-left... Does it makes sense to you?
For that case I would recommend turning off "Center on page", that will make MoI use 0,0,0 as the page origin and you can move your objects to position them where you want to control where they will be printed at.
You can draw a rectangle starting at 0,0 and with your page width and height if you want a visual guide to see what area in model space is going to map to the output page.
Hi All,
I would definitely welcome feature that would allow me to see cut object.
Meaning If I have a object, I would insert a plane and would be able to view from that plane so I know what is inside and how it looks if I cut along that plane.
Now I have to hide faces to get something similar.
This is very useful for multiple objects that have to fit together.
I don't know if this request has been already done.
Is it possible to have the number of points of a curve in the curve properties of the Object properties when you show the details.
It is possible to have this informations with a sequence : - Show Points - Selection of the points of the curves - Details
But perhaps could you add this information in details of the Curve object.
Selection priority setting would be welcome or a pop-up asking which object should be selected (aka Rhino).
Quite often after creating the object from curves I want to do some operations using edges. And as I have curves in the same area I have to hide curves first. This quickly gets annoying.
In Rhino we get a little pop-up when there are multiple objects in the same place so the user can pick the desired one. That, or some setting which would allow you to define priority (for example edges over curves) would be great.
Hi Przemas, it was actually a high priority during Moi's initial design phase to not have the object selection popup that I set up in Rhino, because it is so distracting popping up in your face all the time.
Moi does basically the opposite of that by showing you selection feedback while you are moving your mouse around so you can see what is going to be selected when you click. But the main area where this falls short is when there are curves right over top of edges like you mention. I would like to figure out some kind of pop up for this particular situation but I have not been able to come up with a good design for it as of yet.
SVG format ? For this fun free Snap online from Berkeley! https://snap.berkeley.edu/snap
Works like a charm but here i must convert it! :)
(ps Jens Mönig is the creator of Snap)
@Michael: For me a simple setting where you would be able to set a selection priority would suffice. As you already noticed it becomes a hassle only in a certain type of scenarios, for example when extruding.
Hi Michael, would it be possible to include resizing for background images based on values to be entered (see example photo)? Scaling with the mouse is too inaccurate.
-moritz
Please try updating the ImagePropertiesDialog.htm file (in the ui subfolder in the install) with the new version attached here. That should then give width and height controls on the image properties dialog:
Hi aphaits, unfortunately fillets like that take something like 50 man years of development time to implement.
So it's not something that is easy for me to add directly on my own, it needs to come from a licensed library. There is a library that I've had my eye on that seems promising, but I'm not sure yet how difficult it will be to integrate it into MoI.
I've already worked on attempting similar integration with 2 other libraries so far without success yet.
