Full Version: I miss 123d Design (the Fillet master)
Show messages:  1-5  6-25  26-45  46-65  66-85  86-96
14 Sep 2020   [#6] In reply to [#5]
Yes it was also a disclaimer on the designspark main page from RS components...
"Clarification: the paid add-ons do not provide AutoCAD DXF or DWG import capability"
https://www.rs-online.com/designspark/introducing-the-new-designspark-mechanical-add-on-modules
The " text point file" import looked interesting but I'm not faffing about with yet another workaround,
for what should be a simple 2d 》3d workflow ( I think moi is going to do fine :0)
https://designspark.zendesk.com/hc/en-us/articles/360022341474-How-do-I-format-a-point-curve-text-txt-file-for-import-
https://designspark.zendesk.com/hc/en-us/community/posts/211756129-DXF-Import
14 Sep 2020   [#7]
Tested the new version DesignSparkMAechanical 5.0 : all works fine !:)
Import Export SKP...etc...
Import STEP (from Moi for hard Fillets ;) Export SAT (with little easy tricky thing)
14 Sep 2020   [#8] In reply to [#1]
Hi zarkow,
So you should find that filleting in fusion 360 now, which you can use for free too.
Have you looked at that yet?
If you have a test case and want to see the result from there, i will test for you....
Autodesk migrated all those things together into the "360" bundle. Should be the same powerful engine.
14 Sep 2020   [#9] In reply to [#6]
@ Stephano
I don't know if that interest you but the free DesignSparkMechanical 5.0 has a DXF 2D export!
(and a PDF 3D export! ;)
Here from a Moi Solid (exported to DSM in Step format then Exported from DSM in 2D DXF ) :)
and here your Moi Solid in your 3D PDF favorite! :)
15 Sep 2020   [#10]
So ...some variations (prefere Booelan Union before export Step format from Moi)
"Direct modeling"
15 Sep 2020   [#11] In reply to [#1]
I'd gladly pay a higher price for MoI if it had a more advanced Fillet library.
7 May 2021   [#12] In reply to [#11]
Is it possible to have fillet engine of MOI on Github or somewhere where people who has the knowledge could contribute into making it a much more robust fillet engine? (Just a thought ;)
7 May 2021   [#13] In reply to [#12]
Hi Psygorn,
Sorry no it's not possible to do that.
7 May 2021   [#14] In reply to [#13]
Ah ok. it was just a thought :)
8 May 2021   [#15]
https://www.youtube.com/watch?v=0YK_ZDzt9mI
this video shows how to unlock the possibility of import STEP to Design Spark Mechanical 5.0 (without any paid addons). This way allows you to edit STEP geometry inside the free version of DSM.
There is also a trick on how to export geometry in the free version of DSM.
You should save the file as a native *.rsdoc file. After that, you should change the extension of this file from "rsdoc" to "zip". After changing it to zip you should go inside and find a file with extension "sab" and unzip it.
Next you should use SabSatConverter.exe (command line) which is DSM folder (f.e. C:\Program Files\DesignSpark\DesignSpark Mechanical 5.0\SabSatConverter.exe -i f:\input.sab -o f:\output.sat)
Sat you may import to MoI. So free DSM allows you to import and export :)
Edit: @PILOU: How do you imported solid to BricsCAD shape? I can see there only *.skp file import,
8 May 2021   [#16] In reply to [#15]
Seems i have all yet done for make some bridges on the 2 ways between MOI and Design Sparks Mechanical! ;)
https://moi3d.com/forum/index.php?webtag=MOI&msg=6186.1
8 May 2021   [#17] In reply to [#15]
Briscad Shape : yes it's very easy Moi to it : there is an direct export SKP from Moi! ;)
BricsCad to Moi : more complicated because it has only DWG (numerous versions), DXF​, DAE,FBX,STL but not SKP or OBJ
The dxf is maybe not sufficient for some pieces!
So you must make some conversions somwhere!
It's more for make a nice form in Moi then makes cool fillets then export DAE or FBX for any polygons monsters like Blender ...
...or direct render...in some cool free one like Twinmotion :)
8 May 2021   [#18]
@Christian,
if you use Windows, I still have 123 Design and use it.
Let me know and I send you the 123_Design_R2.2_WIN64_2.2.14.exe Installer.
Or google for it, because some official sites still offer a download link.
9 May 2021   [#19] In reply to [#18]
Hi Stefan,
I'd be happy if you send me its installer :)
How large is that?
9 May 2021   [#20]
Hi Psygorn,
371 MB. I would try to send via WeTransfer,
but for that I need your email address.
9 May 2021   [#21] In reply to [#20]
Hi futagoza,
Do you happen to know if the below link is what I am looking for?
https://web.archive.org/web/20170202170834/http://www.123dapp.com/design
I am kind of suspicious of these links sometimes they are infected by computer viruses!
9 May 2021   [#22]
I would not download from such links, only from well known sites.
9 May 2021   [#23]
In my opinion https://web.archive.org/ is more secure place than the others. This is only backup so If site was virused then it backuped it as is. www.123dapp.com was also secure site I think. This is only my opinion but I wouldn`t aware those both site. I don`t know is it possible to switch file to virused one but if it`s possible then it`s possible everywhere.
9 May 2021   [#24] In reply to [#23]
This link is still working: https://autodesk-123d-design.en.lo4d.com/windows
it is the official download link, btw !
9 May 2021   [#25] In reply to [#24]
I am not sure that is the official one!
It's just a Donwnloader of progs! ;)
https://www.lo4d.com/corp/about
But will be very cool if you can install it!
