Full Version: I miss 123d Design (the Fillet master)
Show messages:  1-9  10-29  30-49  50-69  70-89  90-96
15 Sep 2020   [#10]
So ...some variations (prefere Booelan Union before export Step format from Moi)
"Direct modeling"
15 Sep 2020   [#11] In reply to [#1]
I'd gladly pay a higher price for MoI if it had a more advanced Fillet library.
7 May 2021   [#12] In reply to [#11]
Is it possible to have fillet engine of MOI on Github or somewhere where people who has the knowledge could contribute into making it a much more robust fillet engine? (Just a thought ;)
7 May 2021   [#13] In reply to [#12]
Hi Psygorn,
Sorry no it's not possible to do that.
7 May 2021   [#14] In reply to [#13]
Ah ok. it was just a thought :)
8 May 2021   [#15]
https://www.youtube.com/watch?v=0YK_ZDzt9mI
this video shows how to unlock the possibility of import STEP to Design Spark Mechanical 5.0 (without any paid addons). This way allows you to edit STEP geometry inside the free version of DSM.
There is also a trick on how to export geometry in the free version of DSM.
You should save the file as a native *.rsdoc file. After that, you should change the extension of this file from "rsdoc" to "zip". After changing it to zip you should go inside and find a file with extension "sab" and unzip it.
Next you should use SabSatConverter.exe (command line) which is DSM folder (f.e. C:\Program Files\DesignSpark\DesignSpark Mechanical 5.0\SabSatConverter.exe -i f:\input.sab -o f:\output.sat)
Sat you may import to MoI. So free DSM allows you to import and export :)
Edit: @PILOU: How do you imported solid to BricsCAD shape? I can see there only *.skp file import,
8 May 2021   [#16] In reply to [#15]
Seems i have all yet done for make some bridges on the 2 ways between MOI and Design Sparks Mechanical! ;)
https://moi3d.com/forum/index.php?webtag=MOI&msg=6186.1
8 May 2021   [#17] In reply to [#15]
Briscad Shape : yes it's very easy Moi to it : there is an direct export SKP from Moi! ;)
BricsCad to Moi : more complicated because it has only DWG (numerous versions), DXF​, DAE,FBX,STL but not SKP or OBJ
The dxf is maybe not sufficient for some pieces!
So you must make some conversions somwhere!
It's more for make a nice form in Moi then makes cool fillets then export DAE or FBX for any polygons monsters like Blender ...
...or direct render...in some cool free one like Twinmotion :)
8 May 2021   [#18]
@Christian,
if you use Windows, I still have 123 Design and use it.
Let me know and I send you the 123_Design_R2.2_WIN64_2.2.14.exe Installer.
Or google for it, because some official sites still offer a download link.
9 May 2021   [#19] In reply to [#18]
Hi Stefan,
I'd be happy if you send me its installer :)
How large is that?
9 May 2021   [#20]
Hi Psygorn,
371 MB. I would try to send via WeTransfer,
but for that I need your email address.
9 May 2021   [#21] In reply to [#20]
Hi futagoza,
Do you happen to know if the below link is what I am looking for?
https://web.archive.org/web/20170202170834/http://www.123dapp.com/design
I am kind of suspicious of these links sometimes they are infected by computer viruses!
9 May 2021   [#22]
I would not download from such links, only from well known sites.
9 May 2021   [#23]
In my opinion https://web.archive.org/ is more secure place than the others. This is only backup so If site was virused then it backuped it as is. www.123dapp.com was also secure site I think. This is only my opinion but I wouldn`t aware those both site. I don`t know is it possible to switch file to virused one but if it`s possible then it`s possible everywhere.
9 May 2021   [#24] In reply to [#23]
This link is still working: https://autodesk-123d-design.en.lo4d.com/windows
it is the official download link, btw !
9 May 2021   [#25] In reply to [#24]
I am not sure that is the official one!
It's just a Donwnloader of progs! ;)
https://www.lo4d.com/corp/about
But will be very cool if you can install it!
9 May 2021   [#26]
I've uploaded Autodesk 123D_Design_R2.2_WIN64_2.2.14 on Gofile, here's the link :
https://gofile.io/d/w0eOO9
I've intergrated in the archive, the manual and shortcuts guide aswell.
It works perfectly if you launch it offline, if not, you will not be able to exit the program properly unless killing the task.
9 May 2021   [#27]
Thank you guys :)
By the way could anyone of u compare Onshape with 123D Design? it terms of lightweightness & filleting ability?
I also faced few problems regarding Uninstallation of Fusion 360 (I know this is not a place to seek help for that ;) but I thought maybe any one of you could help, So, If u think you can help I will tell u what my problem is!)
10 May 2021   [#28] In reply to [#27]
OnShape is a monster like Fusion 360! ;)
123D is a lighter one !
both can resolve some of complex fillets
Uninstall fusion 360 must be done (in windows) like usual other progs!
Config Panel / Uninstall Progs...
10 May 2021   [#29] In reply to [#28]
Yes it should be like what you mentioned above, except the fact that it doesn't work! Windows was not able to uninstall it ;)
So, I did a research and found this:
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-do-a-clean-uninstall-of-Autodesk-Fusion-360.html
According to above website :
1-Go to the Start Menu > Control Panel > Uninstall Programs.
2-Select the existing Autodesk Fusion 360 entry from the list and click Uninstall.
-> *Sometimes this step will not work depending on what happened to the installation files. If that is the case move onto the manual deletion steps below)*
In my case this didn't work! So, I went to this link:
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-do-an-automatic-Clean-Uninstall-for-Autodesk-Fusion-360.html
and downloaded "Fusion_360_Cleaner.zip for Windows" and then executed it! It seems it was able to remove Fusion 360. But my problem is that when I go to Control Panel\All Control Panel Items\Programs and Features I still see Fusion 360 ( however the icon is not there but it says it has occupied 2.54 GB on my drive!
Edit: I just need a companion program for MOI to do the fillet job! While I am waiting for MOI to improve its filleting abilities :)
So, I am looking for a preferably lightweight and free/open source program. if you have worked with Onshape & 123D Design before which one you suggest?
