Full Version: Moi <> Blender !
Show messages:  1-16  17-36  37-56  57-69
13 Oct 2024   [#57]
Hello, its working fine in Moi 5 beta and Blender 4.2.2 except the scale, but i dont understand how to do the 'exact' thing : )
Michael, can you elaborate? I've got 2 new icons and don't use a shortkey. Thanks.
13 Oct 2024   [#58] In reply to [#57]
Hi Carlos,
Do you remember how you set up the icons?
13 Oct 2024   [#59]
Hello Michael,
I just followed the instructions - https://github.com/Flowgun/BMOI_Connector/tree/master - and the 2 icons showed up.
Thanks a lot.
13 Oct 2024   [#60] In reply to [#59]
Hi Carlos, so go to c:\Users\<username>\AppData\Roaming\Moi\startup and there should be a file there named "97 BMoi.js", replace it with the one attached here.
This one has the "exact" parameter added in to the import button's command.
Does that work?
97 BMoi.js
13 Oct 2024   [#61]
Yes, its working! Thanks a lot, Michael.
15 Oct 2024   [#62] In reply to [#56]
It works. Thanks!
I leave here a link to updated OD_copypaste script for Zbrush that will work fine with newer Zbrush versions. For users that would like to use Moi3D and Zbrush connection. The script is in comments below.
https://www.zbrushcentral.com/t/useful-tool-to-copy-and-paste-geometry-between-zbrush-and-other-3d-editors/408590
15 Oct 2024   [#63] In reply to [#60]
Hey, that's useful, thanks Michael!
15 Oct 2024   [#64]
Hi Michael, will it work on a Mac Intel? Thanks.
15 Oct 2024   [#65] In reply to [#64]
Hi Carlos,
Are you asking about this one you linked earlier? :
It looks like it's all done with script so I think it should work on Mac as well. But looks like there aren't any install instructions for Mac.
On Mac the MOI appdata folder is located at ~/Library/Application Support/Moi
15 Oct 2024   [#66]
Yes, its working nicely. Thank you so much.
15 Oct 2024   [#67]
This script will save me time in my workflow, maybe a couple of hours per month.
Thanks to everyone involved: Michael, TitusLVR, Flowgun and Max Smirnov.
Agree with Nameless about "export curves from MoI and turn them into bezier curves in Blender".
Carlos
25 Oct 2024   [#68]
18 Jan 2025   [#69] In reply to [#68]
This is the plug-in/add-on/script I am using to exchange between MOI3D and Blender. Works great.
