Full Version: Moi <> Blender !
Show messages:  1-12  13-32  33-52  53-69
7 Jan 2024   [#53] In reply to [#51]
What functionality does the Plasticity to Blender have? I have not played with Plasticity in several months, since my trial expired.
8 Jan 2024   [#54] In reply to [#53]
More details about the bridge between plasticity and blender here
https://youtu.be/xOftfx05l14?si=dBXViDLFaymCkYBY
and here - at the very beginning
https://www.youtube.com/live/FGLLv-LG-Oc?si=4UTcq-9kynsn9UC3
13 Oct 2024   [#55] In reply to [#37]
Absolutely love OD_Copypaste tool.
In Moi3D after pasting object, it is always in the center of the scene. Sometimes the scale is changing in relation to the model exported from other applications. How can this be fixed and objects keep position in the scene and proper scale?
13 Oct 2024   [#56] In reply to [#55]
Hi Talik,
It looks like it's based off of Max's OBJ Import script, you can pass in a parameter "exact" to the paste script to disable the resizing and repositioning.
So go to the keyboard shortcut that you use for the paste, and set up the command part like this:
ODPasteFromExternal exact
13 Oct 2024   [#57]
Hello, its working fine in Moi 5 beta and Blender 4.2.2 except the scale, but i dont understand how to do the 'exact' thing : )
Michael, can you elaborate? I've got 2 new icons and don't use a shortkey. Thanks.
13 Oct 2024   [#58] In reply to [#57]
Hi Carlos,
Do you remember how you set up the icons?
13 Oct 2024   [#59]
Hello Michael,
I just followed the instructions - https://github.com/Flowgun/BMOI_Connector/tree/master - and the 2 icons showed up.
Thanks a lot.
13 Oct 2024   [#60] In reply to [#59]
Hi Carlos, so go to c:\Users\<username>\AppData\Roaming\Moi\startup and there should be a file there named "97 BMoi.js", replace it with the one attached here.
This one has the "exact" parameter added in to the import button's command.
Does that work?
97 BMoi.js
13 Oct 2024   [#61]
Yes, its working! Thanks a lot, Michael.
15 Oct 2024   [#62] In reply to [#56]
It works. Thanks!
I leave here a link to updated OD_copypaste script for Zbrush that will work fine with newer Zbrush versions. For users that would like to use Moi3D and Zbrush connection. The script is in comments below.
https://www.zbrushcentral.com/t/useful-tool-to-copy-and-paste-geometry-between-zbrush-and-other-3d-editors/408590
15 Oct 2024   [#63] In reply to [#60]
Hey, that's useful, thanks Michael!
15 Oct 2024   [#64]
Hi Michael, will it work on a Mac Intel? Thanks.
15 Oct 2024   [#65] In reply to [#64]
Hi Carlos,
Are you asking about this one you linked earlier? :
It looks like it's all done with script so I think it should work on Mac as well. But looks like there aren't any install instructions for Mac.
On Mac the MOI appdata folder is located at ~/Library/Application Support/Moi
15 Oct 2024   [#66]
Yes, its working nicely. Thank you so much.
15 Oct 2024   [#67]
This script will save me time in my workflow, maybe a couple of hours per month.
Thanks to everyone involved: Michael, TitusLVR, Flowgun and Max Smirnov.
Agree with Nameless about "export curves from MoI and turn them into bezier curves in Blender".
Carlos
25 Oct 2024   [#68]
18 Jan 2025   [#69] In reply to [#68]
This is the plug-in/add-on/script I am using to exchange between MOI3D and Blender. Works great.
