Full Version: Node Wish List
Show messages:  1-15  16-35  36-55  56-75  76-95  96-115  116-135  …  416-425
11 Dec 2019   [#56]
Offset DotScreen as desired for rasterImage output may easily be achieved with split node
and Remapper node allows for adjustment of image contrast.
12 Dec 2019   [#57]
New ImgSampler Node release
This node uses Max's heightmap routine for converting an image to data points.
Copy the ImgSampler.js to the directory:
C:\Users\<UserName>\AppData\Roaming\Moi\nodeeditor\nodes\extensions
I would like to thanks James for helping out with testing and some fantastic node designs.
Updated. Added curves for lofting 3d surfaces from image.
Wayne
13 Dec 2019   [#58]
Wayne
Congrats to your latest node contribution...I was so happy to help.
ImgSampler will be very useful, not just for 3d modelling but also for 2d graphic design (eg signage:
cnc router or laser cutting).
I have been contemplating using ImgSampler for creating a Line Screen Image as per copperplate etching.
When it came to doing it, it turned out to be so simple.
So, thank you so much,
lineArtSiouxsie.nod
13 Dec 2019   [#59] In reply to [#58]
James,
This one is great. That pattern style is going on my CNC router today.
Thank you, Looking forward to another node development.
Wayne
13 Dec 2019   [#60] In reply to [#57]
W-O-W
W-O-W
W-O-W
13 Dec 2019   [#61]
Great NODE guys, please excuse my ignorance but how do you load the image into the node?
Also for some added inspiration on this tangent have a look at
https://www.lostminds.com/vectoraster7/
https://www.lostminds.com/patternodes2/
13 Dec 2019   [#62] In reply to [#60]
Hi Wayne
If i test your node i haven't the same result
look at my screenshot
13 Dec 2019   [#63] In reply to [#61]
HI AlexPolo,
Just mouse click inside the picture frame to load an image. Set the resolution of the image before loading the image. It is the first released version. Improvements will made from user feed back.
I will check out the referances.
Wayne
13 Dec 2019   [#64] In reply to [#62]
Hi Finema,
Set the resolution of the knob, then reload the image. I will be making improvements on the interface.
Thank you,
Wayne
13 Dec 2019   [#65] In reply to [#64]
thanks Wayne, it's perfect !
good job !
13 Dec 2019   [#66]
Hi all,
I have red squares for reRange and PointExt :-( so I can't test it, unfortunately.
Where do I find those two and where do I have to install those?
I had this problem in the past too, with another node.
Is there an up to date alphabetic list of all required things for node editor,
where one can find all in one place, i.e. like a complete GitHub repository?
13 Dec 2019   [#67] In reply to [#66]
Normally last version of Node Editor is here managed by James
http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.1
13 Dec 2019   [#68]
Thank you Pilou, that did the trick! :-)
13 Dec 2019   [#69]
Hi Wayne,
I have red square highlight on image sampler node and cant load image file. I have updated node editor to current version and placed node in correct location in USER/APPDATA/ROAMING location.
Something else missing?
13 Dec 2019   [#70] In reply to [#69]
Alex
Sorry, I had not yet updated CURRENT NODEEDITOR FOLDER to include ImgSampler.
Please reload with updated zip file attached to this post:
Have a great weekend
13 Dec 2019   [#71] In reply to [#70]
James,
Can you holdup on including the new node into the zip file. There are some graphic updates that are being worked on.
Thank you,
Wayne
13 Dec 2019   [#72] In reply to [#70]
Thanks all working now.
looking good.
Message 9581.73 was deleted
Message 9581.74 was deleted
13 Dec 2019   [#75]
Updated ImgSample.js node at:
https://moi3d.com/forum/index.php?webtag=MOI&msg=9581.57
Wayne
