Full Version: MoI node editor for beginner
Show messages:  1-8  9-28  29-48  49-54
30 May 2024   [#49] In reply to [#48]
Hi mike,
> i see the exact same thing. the 0.97 install seems to be missing something. did i miss a step?
Can you maybe describe a bit more about what problem you're seeing?
Is it that the CustomUI "NodeEdit" button is showing a blank window?
30 May 2024   [#50]
yes, exactly
it is that the CustomUI "NodeEdit" button is showing a blank window
i installed this version of the nodeeditor
https://moiscript.weebly.com/install-elephant.html
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/nodeeditor_1.zip
@'y'@ 0.97
30 May 2024   [#51] In reply to [#50]
Hi mike,
Do you possibly have the .zip file name in the path?
Like nodeeditor_1\nodeeditor\index.htm ?
If so then it won't find it because it's looking for
moi://appdata/nodeeditor/index.html
and you've instead got
moi://appdata/nodeeditor_1/nodeeditor/index.html
If that isn't it please show a screenshot of where you have it installed to.
30 May 2024   [#52]
sure, thanks
here is my screenshot
30 May 2024   [#53] In reply to [#52]
Hi mike, that sure looks correct.
I think maybe that nodeeditor might be an old version from moi v3 that is expecting to be put in the "c:\Program Files" install folder instead of in appdata.
Try with this one instead:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.10
30 May 2024   [#54]
great thanks,
that works -- awesome :)
