Full Version: Free 3DM importer add-on for Blender
Show messages: All  1-4  5-11
12 Dec 2018   [#5] In reply to [#4]
MoI's mesher is the best, yes. But a dynamic bridge between MoI and Blender would be very nice.
12 Dec 2018   [#6] In reply to [#2]
Here's a response from the Blender 3DM add-on developer:
"It currently needs indeed the render meshes (display mesh), but I’ll be using Rhino Compute in the (near-ish) future, so that importing a 3DM without render meshes in the file will use a (local) Rhino instance for the meshing. You could of course also request the Moi 3d developer to save the display meshes as well…"
Regards,
Metin
Message 9171.7 was deleted
12 Dec 2018   [#8] In reply to [#6]
Hi Metin, that's great that he has already got a solution planned for that!
It doesn't really work for MoI to save display meshes in 3DM files because it greatly increases file sizes. There's also other problems as well, see here for some previous discussion:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5325.5
http://moi3d.com/forum/index.php?webtag=MOI&msg=5875.3
12 Dec 2018   [#9]
What is "3DM without render meshes in the file will use a (local) Rhino instance for the meshing"
a tranform nurbs surfaces in a mesh ?
12 Dec 2018   [#10] In reply to [#9]
Hi Pilou, it sounds like it will use a locally installed Rhino to make the mesh, communicating with it from within the Blender plug-in. You'll probably get better results just exporting to .obj format out of MoI though rather than using the plug-in.
13 Dec 2018   [#11] In reply to [#10]
Got it. Well, it was almost good news. ;-)
Regards,
M7
