Full Version: Newb: help with Arm and belly contours for solid body guitars
Show messages:  1-16  17-36  37-56  57-76  77-96  97-99
29 May 2018   [#37]
This is so awesome, being able to build the entire guitar as it was modeled in MOI! Seeing this I'm starting to think that NURBS modelling is actually the better paradigm (even for semi-organic shapes), if one can "escape" the polygonal mindset.
10 Jun 2018   [#38]
a few improved renders - using SimLab free edition.
10 Jun 2018   [#39] In reply to [#38]
Hello!
A pretty simple material setup, but very nice render this time :)
10 Jun 2018   [#40] In reply to [#39]
Thanks Marco, Yes - still not great - but better - have a lot to learn :)
10 Jun 2018   [#41] In reply to [#40]
You're welcome.
Anyway, beyond the rendering, it's a very good 3d model.
I don't remember well but maybe in Simlab Composer there's some procedural material that doesn't require UV map.
Check it out.
For very quick rendering with simple material setup, but anyway with a very good quality, I often use the "Shaders" in 3D-Coat.
They don't require any UV map and are applied directly to the hi-poly mesh object (either Voxel or standard polygonal model)
Ciao!
12 Jun 2018   [#42] In reply to [#41]
Thanks for the tips on rendering - much appreciated.
12 Jun 2018   [#43] In reply to [#42]
You're welcome VEGASGUITARS.
22 Jul 2018   [#44]
Here's a new routing scheme for the "Ione" model - this one has three single coil pickup slots and a tremolo cavity . . . working on the pickguard.
23 Jul 2018   [#45] In reply to [#44]
Here's the Ione model with humbuckers and two volume two tone control spaces. The hope is to mill the three designs in several scale lengths and send them to Premier magazine.
23 Jul 2018   [#46] In reply to [#45]
Very high quality model!! Congrats!!
23 Jul 2018   [#47] In reply to [#46]
Thanks Marco!
6 Aug 2018   [#48]
Having trouble filleting the back of this model - any suggestions? The top is fine. Thanks for the help.
6 Aug 2018   [#49] In reply to [#48]
Hi Neil, what fillet radius are you trying to use?
There are some pretty tight bends in your back outline here:
It's problematic for filleting to have a tight bend in the outline that is smaller than the fillet radius. It means the fillet will have to try and bunch up on itself like this:
That type of situation can cause filleting to fail. So if you know you want to fillet that back you'd probably want to keep those tight bends out of the model until later on.
When doing a fillet of radius 0.05 it gives a partial result, with those areas missing:
That definitely makes me think those tight bend areas are the problem.
One way to make progress would be to slice out those areas for now something like this:
Now without those bends in the outline you can go ahead and fillet the back:
And hopefully you now have a smaller area to work on fixing rather than the whole back.
Hope that makes sense.
neil_fillet_back1.jpg  neil_fillet_back2.jpg  neil_fillet_back3.jpg  neil_fillet_back4.jpg  neil_fillet_back5.jpg
6 Aug 2018   [#50] In reply to [#48]
Hi Neil, also over here a fillet radius up to around 0.04 looks like it works ok but not much larger than that with those tight bends in the outline.
If you remove the tight bends as shown above you can then go larger.
If you know you want to put a fillet on some area you kind of need to keep tight bends out of there until later on.
6 Aug 2018   [#51] In reply to [#50]
Thanks Michael - Excellent - thank you for the educational/detailed reply - that solves the problem. Will do!
8 Aug 2018   [#52] In reply to [#51]
Thanks again to Michael for the help. This this is pretty good - would've liked the fillet to be .625 but .25 will have to do. - can always use a 3/8" roundover bit on it. :)
9 Aug 2018   [#53] In reply to [#52]
Hi Neil,
try these reworked curves to get the larger fillet.
Barry
Reworked curves.3dm
9 Aug 2018   [#54] In reply to [#53]
Thanks Barry - what exactly did you do? The shape looked about the same. Was able to get this one to .4 roundover which is pretty close.
10 Aug 2018   [#55] In reply to [#54]
Hi Neil,
I reworked the areas shown in the photo.
I moved your arm cut over slightly as the thickness from front to back was to thin for a 0.25 fillet top and 0.625 fillet back.
Also the neck cut out curve had a sharp corner where it should have blended and gave a strange result when Boolean difference was applied.
This was the order I filleted.
1) Fillet back 0.625 but not the top edge.
2) Fillet top 0.25 again not top edge.
3) Boolean difference neck cut out.
4) Fillet top edge 0.2
Attached is the result.
Hope this helps
Barry
rework .625rad.zip
10 Aug 2018   [#56] In reply to [#55]
Thanks Barry!
