Full Version: Newb: help with Arm and belly contours for solid body guitars
Show messages:  1-18  19-38  39-58  59-78  79-98  99
18 May 2018   [#19]
I took a look at the other shape modification below. The only way I know how to make it without a seam or a noticeable transition, is to make a cutting surface (magenta colored curve) and slice a cut across the entire guitar body.
To do so, extrude the guitar body about a quarter inch taller than you need. So if the final guitar body is to be 1.75" thick, extrude it to 2".
Draw the magenta colored curve. I show it with the control points turned on. Note in the Left View that the top 3 control points are horizontally aligned. (Your alignment tools will also work to align control points if they are selected.
Extrude this curve across the entire guitar body.
Boolean Diff this surface with the guitar body and delete the top portion of the body. Note that the angle of the magenta color curve is important as you don't want to modify the shapes in other areas of the guitar.
Fillet at 0.2" Shape: Const Dist
19 May 2018   [#20] In reply to [#19]
Thanks Ed - that's excellent work. Can't wait to try that.
21 May 2018   [#21]
Many thanks to Micheal, Ed and Barry for the guidance with the guitar contouring - learned a lot! Not to mention the hours of trial and error and headaches I was saved. :)
Here are the results - Michael's help with the solids, edges and curves. Barry's method for arm contour. Ed's method for belly contour and filleting.
23 May 2018   [#22]
Although there is more work to do - here is a shot of the neck and body designed here with expert forum help. This has been a real amazing learning experience - thanks very much for sharing your knowledge. Now that the program is getting more familiar - want to try some more creative ideas. Like a neck/body scarf joint like the old Valley Arts guitars had - and their Korean counterparts.
23 May 2018   [#23] In reply to [#22]
That's some great progress in a pretty short time so far Neil!
Yes definitely things will continue to get easier as you gain more and more familiarity.
23 May 2018   [#24]
Looks great Neil. Be sure to post a photo of the completed guitar.
23 May 2018   [#25] In reply to [#24]
Thanks Ed! you can count on that. Finding that milling a neck is tricky - went through some mdf last night getting settings right with the machine and CAM programming as well.
24 May 2018   [#26]
Thanks to the expert help in this forum - here is the first attempt at milling a neck modeled in MoI3D. :) The transitions came out great - after milling it took about 20 minutes to cut out on the band saw and sand with the random orbital with 180 grit, then rubbed on a little boiled linseed oil to get to the state in the photos. Of course more work is needed - but a far cry less than making it from scratch by hand. This is what this endeavor is all about - getting much needed assistance at the shop. Today is a fun day. Next project will be getting the headstock tuning key holes and cutaway so the work can be flipped over and so milled on both sides.
Video link of short clips of the milling of the neck profile: https://youtu.be/wTbd2urCXBM
24 May 2018   [#27] In reply to [#26]
AMAZING!!!!!
My huge congratulation.
Very, very good job.
BRAVO!!!!
24 May 2018   [#28] In reply to [#26]
Hi Neil,
great to see your efforts with Moi have reaped results.
Barry
24 May 2018   [#29]
Unreal to reality! Excellent!
24 May 2018   [#30] In reply to [#26]
Fantastic neck Neil!
Marc
24 May 2018   [#31]
Looks great!
Always fun to see a MoI 3D model translated into a physical object whether it be in wood, metal, foam, or 3D printed plastic.
26 May 2018   [#32]
A couple low res renderings of the body and neck made with MoI3D - looking forward to more challenging endeavors after building this guitar. The body is a tad too thick and a few other things that need to be redesigned for production - but all in all pretty good thanks to the generous sharing of information here.
27 May 2018   [#33] In reply to [#32]
Hmmm...honestly, not so good those renderings...
They fail to do justice to the very nice and very well done original product!
Bad material setup.
27 May 2018   [#34] In reply to [#33]
Obviously don't know much about rendering - sorry for the poor quality here are the pictures in MoI.
27 May 2018   [#35] In reply to [#34]
Very good modelling!!
And about renderings...no one is born knowing everything :)
A very good knowledge of the rendering' principles takes months to be learned...and a lot, lot of practicing :)
27 May 2018   [#36] In reply to [#35]
Thank you for all the input and suggestions Marco! Well noted.
29 May 2018   [#37]
This is so awesome, being able to build the entire guitar as it was modeled in MOI! Seeing this I'm starting to think that NURBS modelling is actually the better paradigm (even for semi-organic shapes), if one can "escape" the polygonal mindset.
10 Jun 2018   [#38]
a few improved renders - using SimLab free edition.
