Full Version: Auto-retopology algorithms compared
Show messages:  1-20  21-40  41-60  61-65
29 Aug 2018   [#21] In reply to [#20]
Good suggestion, Stefan, thanks. I'm going to post it at the 3D-Coat forum as well.
29 Aug 2018   [#22] In reply to [#19]
Hi Metin,
> ... the algorithm includes a sharp edge detection feature:
Yes that probably helps some CAD models from just being completely destroyed but I'd think that having a uniform size output is not going to work well with many mechanical objects.
It would be good to see the result on something like this for example:
https://grabcad.com/library/engine-v-twin-4-valve-heads-1
In the paper there is one screenshot of a motorcycle that was converted and it looks pretty weird to me, many areas are mutated pretty significantly.
This isn't to say at all that it's not a useful tool when used where it is intended.
29 Aug 2018   [#23] In reply to [#19]
Hi Metin, I've attached an example CAD model here (taken from https://grabcad.com/library/ngoc-mai-tug-boat-1), it would be interesting to see what the output is on these:
QuadTest_3dm.zip
30 Aug 2018   [#24]
I've ran your example through QuadriFlow using these parameters:
quadriflow -i examples/Untitled.obj -o examples/untitled_quadriflow.obj -f 3200
The result is pretty bad, and that's an understatement (first one comes from N-gon OBJ, the second from Tri OBJ):
Adding the -sharp option gave me a segfault on the first, and abort trap error on the second run. So no results at all.
Too bad ...
- Fabien
Schermafbeelding 2018-08-30 om 09.28.33.png  Schermafbeelding 2018-08-30 om 09.38.30.png
30 Aug 2018   [#25] In reply to [#24]
Hi Fabien, thanks for testing it. That definitely shows to me that it would be really weird to try and bundle that directly with MoI, since that's the kind of stuff that MoI is good at making.
And that doesn't mean that QuadriFlow is bad, just that it is not intended to work on CAD models.
It's also really cool that the authors set it up to compile on multiple platforms and released it under a permissive license as well.
30 Aug 2018   [#26] In reply to [#24]
Come on guys, this algorithm turns technical models into art, what more could you ask for? ;)
OK, I'm convinced. Please keep your polygon mesher as it is, Michael! :D
It's a pity though. For a moment I thought Quadriflow could form the ideal connection between NURBS and quad-poly subdivision modeling.
30 Aug 2018   [#27] In reply to [#26]
Hi Metin, yes over the years I have learned that you often need to take research paper results with a grain of salt, you can't just assume that the results that are shown apply to every situation. Which is fine though, it shouldn't be required that only things that give perfect results in all cases should be published.
But adopting it as a built in feature that users will get surprised by when they use it is a pretty different matter.
30 Aug 2018   [#28] In reply to [#27]
Agreed!
1 Sep 2018   [#29]
At least it works good with organic shapes and maybe they improve it for hard surface cases.
1 Sep 2018   [#30] In reply to [#29]
Hi Stefan,
Quadriflow is definitely worth keeping an eye on.
Did you get the sharp edge option to work? I'm curious how different hard-surface models are retopologized with that option.
1 Sep 2018   [#31]
Hi Metin,
i exported from MoI as high-density triangle mesh and was able to
use QuadrFlow with the -sharp option on the first model. But in
QuadriFlow i used also a higher poly count setting. The second
model failed here too. But for me it makes not much sense to
use also a high poly count setting, to only have many small quads.
But this is no problem for me, because i have ZBrush, in case
i need to auto-retopo a CAD mesh... :-)
1 Sep 2018   [#32] In reply to [#31]
I'm not aware of any auto-retopo process for CAD meshes in ZBrush, can you elaborate? I was under the impression using poly groups was required for good results, which means a lot of manual work to break up the surfaces.
1 Sep 2018   [#33]
Hi Chris,
Paul Gaboury showed once in a video, how to poly group a CAD model fast.
https://www.youtube.com/watch?time_continue=1&v=IzFZfJDQOOM
starts at 39:04.
Then you have also the option with MoI to create with a script random
style colors to a model and can use these for poly groups in ZBrush.
But to be honest why to auto-retopo a *MoI* CAD mesh... MoI has the
best mesher available! :-)
3 Sep 2018   [#34] In reply to [#33]
Thanks for that link. I'll have to watch it several more times.
4 Sep 2018   [#35] In reply to [#32]
Hi Chris,
Here's an image by a company called Kermaco I once found on Pinterest, explaining a multi-stage CAD model retopology process in ZBrush:
I expect you'll have to open the image in a new tab to see the full-size version.
7 Mar 2019   [#36]
Hi Metin and alll,
have you already tried ZRemesher v3? I have not downloaded yet, but i am
very curious how it would remesh the models Michael has posted.
7 Mar 2019   [#37]
BTW. i have just seen that there is an online version of Quadriflow.
https://yichaozhou.com/publication/1805quadriflow/#tool
7 Mar 2019   [#38] In reply to [#37]
Quadriflow online : seems you can't upload your own model for quadrangulate it?
Else Zbrush seems robust :)
7 Mar 2019   [#39]
Sorry, overlooked it ...
So can you try ZRemesher v3 please, with the models Michael provided?
7 Mar 2019   [#40]
Hi Stefan, Pilou and others,
Being in one of my many wrestling matches with the dreaded deadline monster, I regret not having found the time yet to try ZBrush 2019.
From what I've seen in the Pixologic introduction video I’m reasonably excited about ZBrush 2019. Personally I can’t wait to have a go at ZRemesher 3.0 with the new hard surface improvements. The subtool folders are great too, also the ability to use them in Live Boolean mode.
I feel a bit ambivalent about the Spotlight alpha mesher feature. It feels a bit like a revisit of the old Shadowbox, a feature I usually forget during modeling.
The NPR rendering possibilities look very good, but to me that also feels like going back in time about 10 to 15 years, back when finalToon, Pencil+ and Liquid+ were state-of-the-art 3ds Max NPR plug-ins.
Any tips and observations regarding ZBrush 2019 are welcome.
Thanks!
M7
