5-24
25-30
Message 8646.25 was deleted
Hi Marco,
> Do you think I should create a brand new thread for this first official release to give
> it the chance to be viewed and tried by as many users as possible ?
Sure, that sounds like a good idea.
> Meanwhile could you please remove the old thread that I created some days ago named : "A
> possible script for finding "holes" of a planar closed curve" ?
Are you sure you need to have it removed? Since there was some discussion there about possible strategies maybe it could be useful for someone doing research on how to approach a particular kind of script in the future...
Hello Michael.
Ok. I will publish this first beta version of these two scripts in a new thread.
I'm doing some final test and I hope that in a couple of hours, starting now, I should be done.
Unfortunately, like you said, during the last tests the "ClosePt" method for the "Project" command is proving to be too unreliable in many cases.
But I want to close this first beta soon, so i think I should switch to "Direction" mode and calculate the direction based on the bounding box of the container curve.
This will take at least one hour to make some test.
@You : "...Are you sure you need to have it removed? Since there was some discussion there about possible strategies..."
I asked you to remove the other thread because I thought that all the most important things have been addressed here
and all the 5 posts there are only from you and me. No other users.
If you want you can remove it.
Now I go to make the final coding and test.
We'll catch up!
Hey Y'all,
Where is the forum download for lasso select?
http://take.ms/vabjU says "File not Found", after some delay.
Thank you in advance.
Hi MindSet,
It doesn't look like it was uploaded to the forum directly.
Thanks Mike.
Hmm, bummer.
If anyone has a working copy of "lasso select" (and possibly its PDF too), then please consider uploading it.
Many thanks!
5-24
25-30
