 21-40
 41-53
> Seems there is a glitch on your new command Distribute when you define a length!
It looks like you're giving it an invalid length, your length is shorter than the width of the objects.
The command is for distributing objects with even spacing between them across a length. If your length is less than the total width of the objects then it is not possible to do that.
If the distribution length is 1/3 of one object width it looks like this, so another option would be picking the distance instead of putting in numerical value.
And watching how it changes, before the final click.
> Cubes are 10 * 10 *10 !
Then your length should be a minimum of 30 for 3 such cubes to be able to fit with 0 space between them. As you go larger than 30 then there will be spacing added between them.
<  As you go larger than 30 then there will be spacing added between them.
OK ! Was not evident at first view! :)
Confusion (for me) between "on a length" and "absolute distance" between object...
that is an another one existing...
It could be another 1D Scale but limited to the Distance not the objects.
Is it a big deal to have in MoI a Scale option as in ScalePositions in Rhino?
Situation when you have several objects and you want to scale a space between them not the objects?
In Rhino it is even a polar option for objects arrayed circular.
Marek
Hi Marek,
Is it like the ExplodeMove command in Moi?
https://moi3d.com/4.0/docs/moi_command_reference10.htm#explodemove
https://moi3d.com/forum/index.php?webtag=MOI&msg=10060.6
No, not at all:
see this, please:
https://youtu.be/uqOJP1NAJMI?t=511
Marek
Hi Marek,
> No, not at all:
> see this, please:
That is doing the same thing as ExplodeMove in MoI.
Here's a demonstration, compare the result to the video you linked:
Well -
- YES!!!
I was misled by the command name.
Thank you, Michael.
Marek
BTW,
Where can I find a list of all commands as I may not know about other gems of this type?
Marek
Hi Marek, in the reference section of the help file go to "Additional commands":
https://moi3d.com/4.0/docs/moi_command_reference.htm
Great, thank you as I found only these here:
http://kyticka.webzdarma.cz/3d/moi/  - 'List of commands without UI button' - but the older version.
Marek
As always - read the manual first...
 21-40
 41-53
