Full Version: Sheet metal in V4
Show messages:  1-8  9-28  29-48  49-54
5 Dec 2017   [#49] In reply to [#24]
There is one ultimate guide about press brake, it mentioned everything about press brake as well as the bending operation, hope it can be helpful for you. Here is it: https://machinemfg.com/press-brake-ultimate-guide/
5 Dec 2017   [#50]
I believe the ultimate guide to press brake will interest you guys since you care about sheet metal bending. https://machinemfg.com/press-brake-ultimate-guide/
5 Dec 2017   [#51]
Thanks, its very usefull.
10 Dec 2021   [#52] In reply to [#26]
hi
Here an example of my sheet metal workflow for parametrics parts
The workfloor is :
1 - Simple 2D part's drawing . ( complex part's can be import from SOLVESPACE )
2 - Part's extrusion
3 - Part's 3D connection/assembly with junctions .
4 - Final boolean union
5 - Layout with Make2D4Views function
6 - 3D part's export in STEP , SKP ...
7 - Layout export in PDF
i hope it could help you
have a nice day
Chri
MY PARAMETRIC SHEETMETAL WORKFLOW 01.png  MY PARAMETRIC SHEETMETAL WORKFLOW 02.png
11 Dec 2021   [#53] In reply to [#52]
Complex Parametrics part's can be import from SOLVESPACE
Chri
12 Dec 2021   [#54] In reply to [#53]
@Chri!
Hello
The SVG (2d) format of the free Solvespace is compatible to the not so "rustic" free TinkerCad!
Just import inside Tinkercad a SVG file!
