Full Version: Sheet metal in V4
Show messages:  1-7  8-27  28-47  48-54
16 Oct 2016   [#48]
Hi Marco,
In attached is an image showing what i was trying to say.
The idea is to use the Edge selected and translated it to a new position.
I think this might mimic (emphasis on mimic) the sheet metal allowence.
In sheet metal (simgle piece) the thickness and bend allowence is constant, so the user has to figure it out once.
Carlos
5 Dec 2017   [#49] In reply to [#24]
There is one ultimate guide about press brake, it mentioned everything about press brake as well as the bending operation, hope it can be helpful for you. Here is it: https://machinemfg.com/press-brake-ultimate-guide/
5 Dec 2017   [#50]
I believe the ultimate guide to press brake will interest you guys since you care about sheet metal bending. https://machinemfg.com/press-brake-ultimate-guide/
5 Dec 2017   [#51]
Thanks, its very usefull.
10 Dec 2021   [#52] In reply to [#26]
hi
Here an example of my sheet metal workflow for parametrics parts
The workfloor is :
1 - Simple 2D part's drawing . ( complex part's can be import from SOLVESPACE )
2 - Part's extrusion
3 - Part's 3D connection/assembly with junctions .
4 - Final boolean union
5 - Layout with Make2D4Views function
6 - 3D part's export in STEP , SKP ...
7 - Layout export in PDF
i hope it could help you
have a nice day
Chri
MY PARAMETRIC SHEETMETAL WORKFLOW 01.png  MY PARAMETRIC SHEETMETAL WORKFLOW 02.png
11 Dec 2021   [#53] In reply to [#52]
Complex Parametrics part's can be import from SOLVESPACE
Chri
12 Dec 2021   [#54] In reply to [#53]
@Chri!
Hello
The SVG (2d) format of the free Solvespace is compatible to the not so "rustic" free TinkerCad!
Just import inside Tinkercad a SVG file!
