Full Version: Sheet metal in V4
Show messages:  1-11  12-31  32-51  52-54
13 Oct 2016   [#12]
Looks that my request is harder to code than i tought : ) or probably only me will benefit from it.
Ok, and this: (after selecting 1 face of a solid) Copy to clipboard > Paste (same layer or new layer) > Rotate (90º along largest lenght) > Extrude (mouse pointer).
Copy/Paste/Rotate/Extrude are functions already present, nothing new. Its feasible to align this 4 tools in a sequence.
Or a toolbox were the user can (re)place the tools and sequence needed.
Be aware that i've no idea of the work involve on this sugestions.
Carlos
13 Oct 2016   [#13] In reply to [#12]
Hi Carlos, the difficult part currently would be in getting the axis directions from the surface for which way to rotate, there aren't really any functions currently for a script to interrogate a surface and retrieve directions from it, I guess unless a world axis aligned bounding box gives you all that you need.
I do want to add more functions in V4 to enable scripts to retrieve more shape information from surfaces and curves and that's what would probably be required in order to automate what you described above.
A toolbox where you would interact with tools and reorder them would involve a huge amount of work, I mean you could check out Max's nodes library which is basically an environment to do that type of stuff.
13 Oct 2016   [#14] In reply to [#12]
Hi Carlos, you know maybe for the particular case of a plane it would be easier than I had thought since it's possible to get the corner points of the plane from the endpoints of the boundary edges...
What about if instead of choosing X / Y / Z in UI controls like you showed, if you would click on one of its edges to define the pivot axis?
13 Oct 2016   [#15]
'if you would click on one of its edges to define the pivot axis'
Yes, i thing so... the rotation is (always) on/along the middle point of the smallest edge... so a extra click there will define the pivot axis.
Or maybe the World Axis could do, i don't know.
About Max's Nodes: Is completely out of my reach : )
Carlos
13 Oct 2016   [#16] In reply to [#15]
Hi Carlos,
Only fo information: Sweep: profile (required rectangle) + rail (required radius) = quite quick bending workflow. After solid arc modelling it is possible to continue via extrude/face only.
Maybe new tool in V4 - Draw Solid / Arc would be useful.
Mik
13 Oct 2016   [#17]
Draw Solid ARC is basically same function in Solidworks CREATE EDGE FLANGE this could certainly be an easy workflow to create most sheet metal parts with radius and projection angle as an input would be great.
Maybe with a head count for backers with some $$$ this function could be coded.
13 Oct 2016   [#18] In reply to [#15]
Hi Carlos, so let me ask a little more detail about your current workflow.
You wrote:
> The workflow is like this: Select a solid face > Copy to clipboard > Paste > Rotate (usually 90ª) > Extrude. That's it.
For the "select a solid face" is this a single surface like one you made with Construct > Planar or is it a face that is joined to other faces in a solid? Or sometimes either?
Do you use the "Both sides" option in the Extrude step?
You could probably streamline your current steps with the regular MoI toolset by using the Transform > Rotate > Rotate axis command (set RotateAxis on a shortcut key). You'd want to enable the checkbox for "Make copies" so that you'd automatically drop a copy when doing the rotation. You only have to manually enable the "Make copies" checkbox the first time you use it, it will then stay on for the remainder of that program session. Then you'd pick 4 points to do the rotation, first 2 points define the rotation axis, then the next point defines the 0 angle point, then the final point gives the rotation angle. Have Straight Snap turned on so the final point automatically snaps at 90 degree increments. Then right click to end, if you continue to left click it will drop more copies.
It looks like this and should work with a plane of any orientation (here I've just set up a shortcut key for RotateAxis and run it one time previously to enable the "Make copies" checkbox):
Is that any better than your current steps?
13 Oct 2016   [#19]
And no need Manipulator! ;)
13 Oct 2016   [#20] In reply to [#19]
Hi Pilou, yes RotateAxis can give you a lot of flexibility to do a rotation relative to specific points which tends to be difficult to do with manipulators. Manipulators tend to be good at rotating objects around some arbitrary central point, it's a pretty different thing. In CAD the primary focus is on accuracy.
13 Oct 2016   [#21]
Thanks for taking the time.
"For the "select a solid face" is this a single surface like one you made with Construct > Planar or For the "select a solid face" is this a single surface like one you made with Construct > Planar or is it a face that is joined to other faces in a solid? Or sometimes either?? Or sometimes either?"
Is always a face of a solid.
"Do you use the "Both sides" option in the Extrude step?"
No, never.
"Is that any better than your current steps?"
Not so much, first impression my workflow still looks faster, will test it tomorrow at the office, its night here : )
One thing that could improve is if the copy could be selected instead of the first (atm is the original face which remains selected).
This workflow is like this: Selet a face (of a solid) > RotateAxis (shortcut R) with Make copy selected> click 5 times (to set the axis(2) + angle(2) + right click) > Unselect the 1st face (1 click) > Select the new face (1 click) > Extrude (shortcut E). Done. The lenght of the extrusion is live on mouse pointer.
Thank you!
Carlos
13 Oct 2016   [#22] In reply to [#21]
Hi Carlos, thanks for the additional info!
If these steps do what you need I think it will be pretty easy to streamline this with a custom script.
How important is it to have the extrusion live on the mouse pointer? What if it was only entered numerically in an input field, with the benefit being that you'd see the extruded result right as you were doing the rotation and it would remember the last value so if you're doing the same thickness repeatedly there wouldn't be any extra extrude step? Or would that be undesirable?
13 Oct 2016   [#23] In reply to [#22]
Both options (live on mouse and lenght number) will be used (at one time, one or the other), but if i need to choose one i'll go for the 'live on mouse' because often i've to snap on some face/edge/vert.
Carlos
14 Oct 2016   [#24] In reply to [#23]
only for inspiration :-)
https://www.youtube.com/watch?v=m38VqL0t9sk
http://sheetmetal.me/formulas-and-functions/bend-allowance/
We can do it manually of course with respect to bending rules:
... but in future some 'Solid Arc' tool would be sufficient and it could help a lot.
Mik
14 Oct 2016   [#25] In reply to [#24]
For information also , a part of in my workflow:
Chri
14 Oct 2016   [#26] In reply to [#25]
@Chri
Why there are not "temporary" violet rectangular volume ?
Because you make a direct PushPull on the piece ?
Because sometime, maybe there will be more easy to put this temporary box and "pushpull" it than try to find a face to extrude! :)
(no need to orbit in complex position)
And for the Red Blue Yellow : it's allways the same or depending of the "Thickness" of the piece?
(have they same thickness ? )
There is no measure of the thickness of the principal piece! :)
14 Oct 2016   [#27] In reply to [#24]
Hi Mik and Chri, those are some potential things for the future. At the moment I'll see about doing a face rotation helper.
14 Oct 2016   [#28]
I test your workfow vs mine, and mine is a little bit faster (10 vs 9 clicks) to get the result i need.
Anyway, thanks for your help.
Carlos
14 Oct 2016   [#29] In reply to [#28]
Hi Carlos, the thing is that the workflow that I was describing will be much easier for me to automate, so if it produces the result you need tomorrow I will work on a script for you that will remove several of the steps to make it faster.
For example all the points for the rotate axis except a single one for the actual rotation I think should be possible to get set automatically coming from the edge you select. At least that would be the idea.
But that will only be relevant if those manual steps do work to generate your desired result.
14 Oct 2016   [#30]
Ok, thanks a lot.
I was just testing the both workflows looking for some speed gain, and learning something new on the way : )
Carlos
14 Oct 2016   [#31] In reply to [#26]
@PILOU ,
Merci PILOU
Q : question
A : Answers
Q : Why there are not "temporary" violet rectangular volume ? ...
A : because it's easy to draw with M.O.I
Q : And for the Red Blue Yellow : it's allways the same or depending of the "Thickness" of the piece?
A : about thickness : when you draw a sheet metal part , all the part has the same thickness.
( if you need somethings else , you need to weld a new part ).
A : about radius : when you bend a sheetmetal part , you need 2 parameter only , choose between inter radius , exter radius , thickness
A : you need also the angle !
Q : There is no measure of the thickness of the principal piece!
A : thickness and material are often write on the sheet or the part list
Chri
