Show messages:  1-6  …  907-926  927-946  947-966  967-986  987-1006  1007-1026  1027-1046  …  1847-1859
25 Jan 2018   [#967] In reply to [#965]
Ciao Marco,
look here: http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.878
25 Jan 2018   [#968] In reply to [#967]
Thanks!
ASAP I will try.
Ciao.
7 Feb 2018   [#969]
Hello Friends
a new exercise, just to keep the mind trained
nothing special, but the result seems
to me quite high-performance-
have a nice evening everyone
alberto
file a this link:http://www.mediafire.com/file/brdhd15a2kv9jx6/PolySolid.rar
13 Feb 2018   [#970]
Hi Friends
an animation test of a
Mechanical Iris, entirely made in Elephant ....
I think because of the numerous Booleans made
the file is heavy, and this undoubtedly affects
on the yield of the Quartz Knot ...
in any case, for those interested
the file at this link:
http://www.mediafire.com/file/a1zwk4ha6f91dbo/Anim.Mechanical_Iris.zip
best
alberto
13 Feb 2018   [#971] In reply to [#970]
Ciao Alberto!
...ma come cacchio fai a creare certi "mostri" ?
:) :) :) scherzo...
ma...no mi funziona. Mi da in rosso i nodi "Quartz2" e "Display".
In English :
But...how do you create such "monsters" ?
:) :) :) I'm just kidding.
Anyway...it doesn't work for me. I see these nodes in red "Quartz2" and "Display".
Ciao!
P.S. I've tested with latest Moi V4
Marco (mkmd)
13 Feb 2018   [#972]
Ciao Marco
display e quartz 2 sono nodi di Ralf
Hello Marco
display end quartz 2 it Ralf's extention ,
go to this link for download
Have a nice day
alberto
13 Feb 2018   [#973] In reply to [#972]
Thanks for the link but...I really have no time to follow that discussion :)
If you can, please post the two nodes as they're form your actual config.
Thanks!
16 Feb 2018   [#974]
Hello Friends
an interesting example, I think, of creating a surface
transition between two existing ones
also quite stable ......
files at this link :
http://www.mediafire.com/file/5nznz8i85jazkm7/Between_Surf.7z
best
alberto
16 Feb 2018   [#975] In reply to [#974]
StuffitExpander on Mac says:
16 Feb 2018   [#976] In reply to [#973]
Quartz2 is inside here:
r2d3.js
16 Feb 2018   [#977] In reply to [#976]
Wanderful!
...some use case or example ?
16 Feb 2018   [#978] In reply to [#977]
I changed Karstens Quartz node to Quartz2 with the min and max as a input to sync it with the numbers of control points for my path animation Node...
pathanim.3dm
pathanim.nod
16 Feb 2018   [#979] In reply to [#978]
Ralf....I've no words!!
What a wanderful thing you did with the Node Editor!!!
I'm pretty sure that Michael never imagined that one day Moi could have been an animation software !!!
16 Feb 2018   [#980]
Very funny!
12 Mar 2018   [#981] In reply to [#242]
Now we have a free terrific solver who will avoid some headaches of the Nodes Builders fans!
http://moi3d.com/forum/index.php?webtag=MOI&msg=8858.1 :)
13 Mar 2018   [#982]
Hi Friends
I want to share this exercise
a famous mechanism .... " geneva well "
in the attached images I also show the set-up
to create the animation ...
the file is parameterized, so it is possible to modify
the number of slots in the well ...
For interested poeple the file at this link:
http://www.mediafire.com/file/hur565zl2135vsc/Mechanical_Geneva.zip
best
alberto
13 Mar 2018   [#983] In reply to [#982]
Hello Alberto!
As I've said many times here....YOU'RE A MASTER OF NODES!!!
Amazing :)
Here's a quick video : http://take.ms/bV1qz
Ciao!
13 Mar 2018   [#984]
Marco thanks for the nice words..
and for the video you made as a service to all nodeeusers ...
Thanks again
Have a nice evening
alberto
13 Mar 2018   [#985] In reply to [#984]
You're welcome Alberto!
If I may, let me give you only one little suggestion, that maybe you already know.
If you want, you could post a simple capture of Moi's screen with some, or at least, one use case of the wanderful nodes you're post here from time to time.
In this way it's easier for any user to get a quick look of what that particular node does.
And also the user is "encouraged" to download the stuff and play with it.
My two cents :)
Thanks for all your wanderful nodes!
Ciao.
12 Apr 2018   [#986]
Hi Friends
I want to share this Macro with you,certainly useful I Hope
M_Pipe
input:
-curves
-radius
- cap round =0
- cap flat = 1
If the input curves overlap the result
it is only one Brep-
file at this Link :
http://www.mediafire.com/file/wqnulsmi5hn2m3b/M_Pipe.nod
have a nice evening to all
alberto
