Show messages:  1-20  …  781-800  801-820  821-840  841-860  861-880  881-900  901-920  …  1841-1859
8 Dec 2017   [#841] In reply to [#839]
Hello Barry,
yep! Thats exectly what I thought. Possible to make global container to place results and read them in a next iteration back. Ralf - thanks for the contribution - has used something similar in the stream node - only problem - more than one of this node.
I need to have a deeper look - next days.
A nice weekend to all
Karsten
8 Dec 2017   [#842]
The section Learn at this link is some frightening! :)
http://www.grasshopper3d.com
And I don't speak about the documentation Online of the grasshopper components! ;)
http://rhino.github.io/#System
So these (free) PDF books will be our nightstand books next years! :D
http://www.liftarchitects.com/s/Grasshopper-Primer_Second-Edition_090323-rn88.pdf
http://download.mcneel.com/s3/mcneel/grasshopper/1.0/misc/en/Generative%20Algorithms_CaE_Strip%20Morphologies.zip
http://download.mcneel.com/s3/mcneel/grasshopper/1.0/docs/Generative%20Algorithms_CaE_Weaving.pdf
http://s3.amazonaws.com/mcneel/grasshopper/1.0/misc/en/Generative_Algorithms_CaE_Porous_Shell.zip
8 Dec 2017   [#843]
By David Rutten (the Max Smirnov of Grasshopper ! ;)
8 Dec 2017   [#844]
"Slider feedback" links:
http://james-ramsden.com/looping-through-the-grasshopper-canvas/
http://www.grasshopper3d.com/video/permutations?id=2985220%3AVideo%3A962796&page=2#comments
8 Dec 2017   [#845]
Permutations above
9 Dec 2017   [#846] In reply to [#841]
<<<< Ralf - thanks for the contribution - has used something similar in the stream node - only problem - more than one of this node.
Yes - thats right i also did a memory extension which works good .... until you add a second one..
For me there is the end of my understanding of js and the system.....
But there is still Karsten :-)
r2d3.js
9 Dec 2017   [#847]
For Max: last version of the FrenchStrings.txt
include the nodes of Vladimir :)
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/frenchstrings.txt
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/lang.js
10 Dec 2017   [#848] In reply to [#840]
Hello Brian,
<<<Yes, hoopsnake. I wonder if nodeeditor has "feedback" detection code?>>>
I think that's a general problem - no special code is needed. The nodeeditor needs startpoints/nodes to start the calculation from an independent node. In a closed loop we need a intial startpoint and initial value(chicken-egg-problem). At a minimum we need an independent node that defines the step in to the loop and gives the initial value. I think it's possible to solve.
Have a nice day
Karsten
10 Dec 2017   [#849] In reply to [#846]
Hello Ralf,
thanks for sharing. I have to study your nodes now.
Have a nice day
Karsten
11 Dec 2017   [#850]
Hi All,
while searching for Hoopsnake came across these video's
https://www.youtube.com/watch?v=QefqhzIz_ak
https://www.youtube.com/watch?v=SSWudanJc7c
Barry
11 Dec 2017   [#851]
11 Dec 2017   [#852]
Hi Barry,and Friends
in Grasshopper besides " Hoopsnake ", there is also
another Plug called "Anemone ", which also works maybe better,
and there is also the possibility of using " Kangaroo " a physics engine to move
rigid bodies, in various ways ,
but all these tools use a Button , True / False, and a connection Timer, to activate
or deactivate the action .......
and , the input data can all be adjusted by a Slider or direct links to the data in the Canvas-
I have not knowledge of Java Script, but I think it is not very easy
create a Collide / Repulsive tool
in any case, your attempts are very appreciable
do not give up......
alberto
11 Dec 2017   [#853]
Hi all,
is it possible to create a nod from existing node's that stores a count and would not be cleared till it is reset or create a new node that does that.
Barry
11 Dec 2017   [#854] In reply to [#853]
Storing a value seems to be a problem...
I didnt find a way to do it with existing nodes and i created a extension with a memory node.
if you set it to 0 it gives the IN values to the OUT if you set it to 1 it stores the last value and gives this to out...
BUT: if you add a second one it doesnt work anymore...
Somehow both react like one.
Perhaps Karsten finds a solution...
12 Dec 2017   [#855]
2 fully interwoven screens.
12 Dec 2017   [#856] In reply to [#855]
Wanderful!
All these stuff are very useful for renderings of 3D concepts and/or geometric art to include into 2D works (after some post process elaboration)
Thanks a lot.
Message 7777.857 was deleted
14 Dec 2017   [#858]
Intricated!
14 Dec 2017   [#859] In reply to [#857]
Thanks James.
Wanderful as usual!!
Math made art :)
14 Dec 2017   [#860] In reply to [#857]
Hello James,
great result. Thanks for sharing!
A nice day to all
Karsten
