After considerable manipulation a 4 hole Scherk2 surface was created from the basic uv curves.
Only one quadrant of open curves was used. The ends were connected with a through point curve, and then mirror and revolve to get 4 sets.
The through point curves were blended 4 times, and the 8 curves joined. Then network worked quickly. A 3 point circle trimmed the rounded ends.
Vertical copy and revolve of the surface enabled join to work.
Main change:
- The Frame and Point types replaced with the PointArray type. This new type supports 3d arrays of points. For each point you can set x-y-z coordinates, three rotation angles, scale.
Other changes:
Added powerful Math nodes (Basic/Math and Arrays/GenArray)
Now you can add and remove optional input/output slots (right click on a node title to add slot, right click on a slot to remove it)
More intelligent selection tools
You can use shift+left mouse button or middle mouse button to select multiple nodes. Now you can easily move them around. Multiple delete doesn't work at the moment.
Slider and Knob nodes doesn't steal focus anymore when you use them.
You can use mouse wheel to zoom in and out
Added math support for property input fields. For example, you can set variables: a: -pi, radius: 2*pi+10 etc
I'm very pleased to know that your NodeEditor project is still under developing...
Thank you very much for your efforts and for the not ordinary quality of your plugin!
It's something like a very precious pearl, in moi's treasure chest.
I never seriously played with your plugin, so i decided to begin.
At the moment i have just a few questions.
For example, just to begin with some simple tests, i wondered what are the steps needed in order to create a "pointarray" object.
I mean...i see that the "Curve" object requires a "pointarray".
So, how generate this kind of object, starting, let's say, from a selection of point objects ?
Thanks again for your great work and have a nice day.
At the moment I wrote just a core engine of this node system. First beta version has been released, but most of the functions are still unavailable.
Now we need to write nodes. Karsten already wrote a lot of nodes which we can use with the new version. Wait for a while.
Right now only three nodes can create a pointarray objects: GenArray, Point and FRotate.
Hi Max,
I notice that we can now zoom in and out which is excellent.
I'm running MoI on a Surface Pro 4 and the Node Editor UI is a bit to small for my old eyes.
Is it possible to enlarge the UI for high definition Monitors.
If not no problem can work with Windows 10 magnifier.
Many thanks for sharing your work it's keeping my old brain active.
Barry
Extract litegraph-editor-hd.zip file to nodeedit/css folder (overwrite the old css-file)
Also extract moi-litegraph.0.41.zip to nodeedit/core folder to enable >1 zoom levels.
that's correct. Most of the nodes has to be rewritten or need an update - so I started allready. And yes - everything in the new beta seems to work:-)
At the moment I study Max code - especially the pointarray and the frames. The changes here, are the most important at the moment, to get the nodes work.
