7-21
Hi Fleetfoot,
> The moi.css file keeps saying I need permission from S-1-5-21-3930758702359839782-1092893196
> to make changes to this file.
That's pretty mysterious.. Maybe something about the ownership of the file is messed up, I guess you might try taking ownership of it something like described here:
https://support.microsoft.com/en-us/kb/308421
Anyway something involving permissions and file ownership is probably messed up on your file system there.
> Also, why the blank white screen when trying to run Moi3D from the USB stick? It works
> fine on a Windows7 machine, but not 8.1.
You mean the very same USB stick runs ok from Windows 7 but not from 8.1 ?
My best guess is that you've got some kind of different anti-virus running on the 8.1 machine which is blocking various files from being accessed. Probably some kind of interfering process like that is likely.
Hi Samuel,
Thanks for the great work! Tried it and it works cool on my Mac. I may consider some tweaks to reduce contrast between the menus and the workspace. This was one of the first things that I thought would be a nice enhancement to the application UI when I started using MoI.
Background: I'm currently trying/learning MoI (in 30 day trial) and really like it. Its already very productive on my 3D printer.
Regards,
Peet
Awesome - thank you very much!
Cheers,
Tom
不好看
Hi Samuel,
Thanks for the update !
this is great thanks for sharing mate :)
My favorite MoI UI theme by far...
I wish there was a version for the new MoI 4 :(
This is by far my favorite MoI theme. What would it take to update it for v4?
there is another dark UI by user Cody, I work with it at pleasure. He is supposed to update it soon for the latest October Beta. Try that as an alternative. Look for dark grey UI here to find the link.
Cheers,
Axel
@Axel : Username search for "Cody" doesn't seem to bring up anything, and a search for the topic of "dark grey ui" doesn't bring up anything related to v4 either. Please provide a link to the thread/post you are referring to. Thanks !
@Jason : It seems like the main component of this UI edit is the moi.css file from the original zip download. So if you just get that and place it into the ui folder of the beta it will at the very least change the bright blue interface to grey.
As for icons : it seems like the ones in the zip are the orignal, unedited ones (dark lines) so I suppose that the Dark Theme for V3 inverts them dynamically ... maybe ? Only a few need editing anyways and that's trivial to do.
you please look here:
http://moi3d.com/forum/messages.php?webtag=MOI&msg=9242.1
Unfortunately not updated to the latest v4 beta.
Best regards,
Axel
I see, thanks !
Well, tbh the dark and yellow UI from that Cody thread is ... kind of garish, somehow ? Simply using the css from the earlier post is way more elegant imho. And that does work well in V4beta, as confirmed in the screenshot below.
Also, and that's of course a very personal opinion : ungrouping the rollouts into individual buttons makes the UI/UX quite a bit more relaxing as well, as it makes the process of grabbing a given tool way less fidgety - everything is just a scroll flick away. Just a matter of doing some editing inside Sidepane.htm.
It's all remarkably flexible. Fun stuff.
Message 7534.19 was deleted
is that also for the latest beta of v4 with the new dimension tabs?
It's all a matter of personal taste. I was just looking for something dark because it's simply better for (my) eyes instead of starring on something bright. The Cody's one I really liked. The one below is also good. I think the very first from the topic opener was for Mac only?
Cheers,
Axel
Well, if I am not mistaken as far as the colors are concerned the only thing that matters is the .css file, you can ignore everything else in the zip. The OS doesn't matter - replace the moi.css file from your installation with it and see if that works. It sure did for me on Win.
And then from there you can selectively chose what you want to override (probably a handful of icons, but that's about it), and also doing some editing in the .ini (and/or the regular options menu in the application itself) for things like bgcolor and antialising.
7-21
