Full Version: Volume calculator
Show messages:  1  2-21  22-41  42-61  62-76
21 Sep 2015   [#62]
more bugs fixed (and added)
added hotkeys (right arrow / left arrow)
22 Sep 2015   [#63] In reply to [#62]
Hi Max,
it works perfectly.
Cпасибо.
Mik
22 Sep 2015   [#64]
CVolume v2.0 beta 3
- some interface changes
- improved volume/mass/surface area ajustment (now in works with all objects)
- hidden: double click on Density title -> copies material name to style name
22 Sep 2015   [#65] In reply to [#64]
Hi Max,
some error appears repeatedly during opening of ZIP file.
Mik
23 Sep 2015   [#66] In reply to [#65]
Hi Mik,
I accidentally made 7z archive with .zip extension :)
Fixed. Download it again.
23 Sep 2015   [#67] In reply to [#66]
Hi Max,
now it works perfectly!
Copying of material name to style name is beautiful feature.
Do you plan in future to allow adding of custom materials inside script UI?
For example PCB, which contains mechanically many of components with different materials, can be modelled as an one solid for simplification of assemble. For calculation of Centre of Mass of all assemble it should be enough to set only weight of PCB, script can calculate volume of solid and from calculated volume and known weight it can be calculated density.
Probably it will be enough to allow (checkbox) recalculate density in stead of volume when mass is changed and copy as a custom material ( "Object name" for example) to style name.
Thank you for excellent script!
Mik
23 Sep 2015   [#68] In reply to [#67]
Hi Mik
I did't think about this yet.
Everything is possible, but I can't promise it.
Yes, I can add this feature.
23 Sep 2015   [#69] In reply to [#68]
Hi Max,
it will be absolute perfect.
Thanks a lot.
M.
23 Sep 2015   [#70]
Hi Max,
Amazing, works perfectly,
Thank you
James E
23 Sep 2015   [#71]
CVolume v2.0 beta 4
Both features has been added
23 Sep 2015   [#72]
No more features ? It's the final update ?
24 Sep 2015   [#73] In reply to [#72]
Yes, this beta is very close to 2.0 release, but lets wait a couple of days.
24 Sep 2015   [#74] In reply to [#73]
THX for the info!
24 Sep 2015   [#75] In reply to [#71]
Excellent!
Thank you Master Max.
Mik
24 Sep 2015   [#76]
Can we imagine (maybe in another Script)
Selection some volumes and their general Center of Mass
When we move a volume(s) the general Center of Mass moves in the same time ?
