 16-35
 36-55
 56-75
 76
Thanks Dino and Max for this useful script.
I have a small improvement request: In the default MoI user interface some contents of the dialog window is too wide.
-Martin
Hi Martin,
I didn't noticed any problem with the script interface. But it seems like you are using Windows UI scaling feature. I'll make some chаnges in the script to fix it. Wait for the next version.
Hi Max,
it's on my Laptop and Desktop computer both running OS X. I'm not aware of any window scaling.
It's the same for me on OS X.
Hi Max,
Your script is amazing, I have wanted this feature since MoI's beta.
Concerning the display cutoff; I am experiencing this as well. I'm not scaling and my display is 1920 x 1080 in Windows 10.
Again though I am so happy to have the script, thanks for all your hard work in this area!
David W. (Aka: blend3d)
CVolume v2.0 beta 1
Completly rewritten :)
Added:
- Center of mass calculation for solids of different densities. ( style = material )
Fixed:
- Interface width
Hidden features:
- Double click on title to reset group volume
- Double click on group name to switch to the first group (All objects)
- You can use material name as style name (full or partial). The script will set density automatically. For example: "Copper", "Wooden box [Redwood]", "Golden ring"
To do:
- Interface tuning
- Volume/Mass changing for All objects group.
upd: bug fixed. reuploaded.
more bugs fixed (and added)
added hotkeys (right arrow / left arrow)
Hi Max,
it works perfectly.
Cпасибо.
Mik
CVolume v2.0 beta 3
- some interface changes
- improved volume/mass/surface area ajustment (now in works with all objects)
- hidden: double click on Density title -> copies material name to style name
Hi Max,
some error appears repeatedly during opening of ZIP file.
Mik
Hi Mik,
I accidentally made 7z archive with .zip extension :)
Fixed. Download it again.
Hi Max,
now it works perfectly!
Copying of material name to style name is beautiful feature.
Do you plan in future to allow adding of custom materials inside script UI?
For example PCB, which contains mechanically many of components with different materials, can be modelled as an one solid for simplification of assemble. For calculation of Centre of Mass of all assemble it should be enough to set only weight of PCB, script can calculate volume of solid and from calculated volume and known weight it can be calculated density.
Probably it will be enough to allow (checkbox) recalculate density in stead of volume when mass is changed and copy as a custom material ( "Object name" for example) to style name.
Thank you for excellent script!
Mik
Hi Mik
I did't think about this yet.
Everything is possible, but I can't promise it.
Yes, I can add this feature.
Hi Max,
it will be absolute perfect.
Thanks a lot.
M.
Hi Max,
Amazing, works perfectly,
Thank you
James E
CVolume v2.0 beta 4
Both features has been added
No more features ? It's the final update ?
Yes, this beta is very close to 2.0 release, but lets wait a couple of days.
THX for the info!
Excellent!
Thank you Master Max.
Mik
 16-35
 36-55
 56-75
 76
