Full Version: Flow as an "unfold tool"
Show messages:  1-3  4-23  24-28
26 Jun 2019   [#24]
In case of!
Remember there is a little free plugin for SKetchUp by Sdmitch : Sheet Metal Bender
http://sdmitch.blogspot.com
The last free version of Sketchup who can use Plugins is the SketchUp Make 2017 !
Curviloft by Fredo6
For something without "gorge" there is the native function!
26 Jun 2019   [#25] In reply to [#24]
Hey Pilou,
I hope life is good!
I see no images on my end :(
27 Jun 2019   [#26] In reply to [#25]
sorry images come from an external forum so i will change that in a minute!...
27 Jun 2019   [#27]
That's a good find, thanks.
Would love to have this in Moi, maybe Michael could develop it in the future.
Carlos
29 Jun 2019   [#28]
Hi everybody.
Using Flow as an unfold tool is theoretical brilliant. As long as you need no close tolerances for practical produktion.
The "newtral" line is not allways in the middle between the outlines. During the bending process the outside material will
be stretched and the inside material comes under kompression. That means the layer of the inside will be thicker and at the outside thinner; and the newtral line changed allways it's position depending of the relation between bending radius and the
thickness of the material.
For this universitys made a lot of testlines to find a formula for a factor you can use for the rigth unfolded length of
bending bows. For every combination of thickness and inside radius you will have a special K-number.
Example: Inner bending radius = thicknes of the sheet; K-number =0,365
Inner bending radius = 2 x " " ; K-number =0,400
Interpolation is possible.
This exaple works with normal sheets up 5 mm thicknes.
To work with sheets need a lot of expiriences and allways testbendings.
Good luck...... and have fun.
Hans
next time I send a formula
