33-52
53-72
73-92
93-112
113-132
133-152
153-172
193-198
Hi Marco,
nice images! However i have a little suggestions, which Pilou also made once, if i remember correctly.
Is it possible that in the future you post smaller images (and your large ones in the gallery maybe)
because it takes quite a bit time to load the pages and auto resizing them. Zarkow, for example,
does this also now, with his images. Maybe look at Zarkow's images, as an example, to get the
max size for displaying images here, without resizing.
Hello Stefan!
@You : "...Is it possible that in the future you post smaller images (and your large ones in the gallery maybe) because it takes quite a bit time to load the pages and auto resizing them..."
I will certainly do it !!! :)
I apologize for the inconvenience...I forgot to do so.
Thanks for the reminder :)
Thank you Marco,
much appreciated!
...Done :)
I've changed my latest 3 images that I have uploaded here (voronoi doodles)
Now I will post images always under 280-300 Kb each.
Ciao!
...Done 2 :)
I've changed also my other 2 images of "voronoi glass"
Ciao!
Marco (mkdm)
how did you make smooth edges on your gold box?
Hi glmr.
Well...I first chamfered in Moi the edges of the Voronoi walls, as you can see here
Then I exported in obj format and finally loaded in 3D-Coat.
There I have voxelized the imported object and applied a Shader.
Last stage, the render with 3D-Coat's Render Room using its builtin PBR renderer.
I often use this "trick" to create "quick and dirt" rendering with super smooth edges without the need to do the "fillet" stage in Moi.
Using 3D-Coat's Voxels I can get super-exaggerated smooth edges in the blink of an eye.
But in this case you need to create Voxels with very high poly count, many millions, and you need a decent CPU+GPU to do that.
But if you have time to spent and want to do the things with better precision then I'm pretty sure that you can fillet the Voronoi walls directly in Moi.
Anyway...this is just one of many ways to get "smooth" edges on Voronoi structures.
3D-Coa's way is one of my preferred, but only because it fits perfectly in one of my wokflows for "2D/3D image composition".
Quick and easy.
But it's a very personal technique, maybe others can find it too "coarse".
Ciao!
<< you can fillet the Voronoi walls directly in Moi.
With some prudence!
Because there are some sharpen angles in a voronoi diagram and the input will be the best minimum acceptable of all corners!
As there are a lot of them you have all luck that your calcul fillets failed!
Maybe increase the Scale size of the all objects before make general fillet!
10 seconds for 100 objects fillets top faces : but the most difficult is to find the best accessible angle! (20 seconds :)
(I7 4 years old : not sure that the graphic card is influent to the calcul ?
thanks!
Voronoi.v.1.1.2018.03.07
Added X button. Double click this button to reset a diagram.
Added Filter slider. Use it to remove extra small sides of polygons.
http://moi.maxsm.net/item/48
Thank you very much Max!!
Are you running for a prize ? :)
It seems that this Voronoi plugin is a sort of personal challenge for you.
Great job, great job Max!!!
Only a question, if I may...
I did some test but I can't figure out how the new "Filter" affects the output of the Voronoi.
Could you please write something about it ?
Thanks again.
French Version Updated! ;)
http://moiscript.weebly.com/scripts-de-max-smirnov.html
Hi Marco
No, it's not a challenge. I just want to make a good script and then forget about it.
It doesn't affects the output if Corners slider set to 0. Set corners to 100 and the move the Filter slider.
Ciao Max!
@You : "...It doesn't affects the output if Corners slider set to 0. Set corners to 100 and the move the Filter slider..."
Perfect! Got it.
Tested and now is...perfect!!
@You : "...I just want to make a good script and then forget about it..."
OK! Then you can sleep soundly :) You created an
AMAZING script.
Thanks a lot for all your effort.
Ciao!
Max...your wanderful script gave me an inspiration..."How to brake in two each Voronoi cell and make a funny thing"
Look at this video :
http://take.ms/pBFZS
In short the process I have used is :
1 Select all Voronoi curves
2 Apply the "mark curve start" plugin
3 Select again all Voronoi curves
4 Apply the "mark curve middle point" plugin
5 Trim the Voronoi curves with the generated points of steps 2 and 4
6 Close all the "half curves" with the command "closecurve"
You can download all the plugins I've used at :
http://take.ms/uAgYy
Unzip and copy the files into the Moi's "commands" folder.
THOSE CUSTOM COMMANDS WHERE TESTED WITH MOI V3
I suppose they should work also with Moi V4 but I didn't try)
Ciao!
P.S....forgot to say that I've used also another Max's custom command : "PatternSelection"
You can grab it here :
http://take.ms/0F9I8
Ciao!
I was waiting for this moment sooo long. Now your script is perfect, just perfect! Thank you very much!
Hello everyone!
I admit I was tempted to create on the fly a brand new thread but I want to submit this thought to all "colleagues" moiers :)
The new thread I wanted to create should be : "PUBLIC THANKS TO MAX SMIRNOV FOR ALL HIS AMAZING AND PRICELESS JOB!!!"
I think it should deserve much more than this but anyway...tell me what do you think ?
Thanks.
Best thanks is use the Max's scripts! ;)
Yes Pilou!
You're right...but I think that maybe a public thank could b a nice thing for him....I don't know :)
33-52
53-72
73-92
93-112
113-132
133-152
153-172
193-198
