Full Version: Voronoi Script or plugin
Show messages:  1-6  7-26  27-46  47-66  67-86  87-106  107-126  127-146  …  187-198
1 Mar 2018   [#67] In reply to [#63]
Hi glmr,
>>will this fix also keep a similar distance between curves?
yes.
between polygons
1 Mar 2018   [#68] In reply to [#66]
did you make these eggs in Moi3d??? I thought it is possible only with Paneling tools from Rhino
1 Mar 2018   [#69] In reply to [#67]
nice! looking forward for your update
1 Mar 2018   [#70] In reply to [#68]
i used various tools to create the voronoi structure and finally used MoI to model the eggs, so no paneling
with Rhino etc.
3 Mar 2018   [#71]
Voronoi.v.0.98
http://moi.maxsm.net/item/48
3 Mar 2018   [#72] In reply to [#71]
French version! ;)
http://moiscript.weebly.com/scripts-de-max-smirnov.html
4 Mar 2018   [#73] In reply to [#71]
Thanks a lot Max !
4 Mar 2018   [#74]
Thanks Max
4 Mar 2018   [#75]
Always funny!
4 Mar 2018   [#76] In reply to [#75]
how???
4 Mar 2018   [#77] In reply to [#75]
Very very nice!
4 Mar 2018   [#78] In reply to [#76]
<< how???
_Voronoi
Extrude "Tapered"
Flow on a Sphere
Render in free Real Time SimLab Composer Lite (max 1920 * 1080)
Have fun!
Here Corners of Voronoi are >90 so rounded (put 0 if you want sharp forms)
4 Mar 2018   [#79]
Voronoi.v.1.0.2018.03.05
Changed random algorithm.
Fixed bugs.
4 Mar 2018   [#80] In reply to [#79]
Thank you very much for your constant developing!!
Voronoi script is a extremely useful tools to create very different kinds of geometric CG!
I'm experimenting some cool stuff with Moi + Voronoi and iPad Pro.
4 Mar 2018   [#81]
With the new _Voronoi by Max Smirnov:)
Take 2 sets and use the ISect Boolean Function! ( whith Union Sets disabled )
then ExplodeMove hidden function
Have fun!
Here twice the same but you can take any things! :)
PS French Version Updated!
4 Mar 2018   [#82] In reply to [#78]
thanks!
5 Mar 2018   [#83]
Hello Max and everyone.
I had some fun with your Voronoi and the iPad Pro (Affinity Photo, PixelMator, Procreate 4, Snapseed).
Ciao!
Marco (mkdm)
5 Mar 2018   [#84]
almost perfect! the last issue is sharp corners even when smooth is 100%
5 Mar 2018   [#85] In reply to [#84]
it's actually no issue... MoI has all the tools to get the desired results.
You can't expect that a script always does all the work for you!
5 Mar 2018   [#86] In reply to [#85]
Hi Stefan!
@You : "...You can't expect that a script always does all the work for you!..."
I completely agree :)
The "manual stage" it's always necessary and, I would say, mandatory.
I agree.
