5-24
25-44
45-64
65-84
85-104
105-124
125-144
185-198
less than one half =)
> will this fix also keep a similar distance between curves?
The usual trick is to have a distance between the edges was that one draws
a control point curve around the corners of each cells and offset then a little
bit inwards.
That's how i have done it in the past with my Voronoi Eggs.
https://www.behance.net/gallery/34247989/Voronoi-Egg-CVT
Hi glmr,
yes.
between polygons
did you make these eggs in Moi3d??? I thought it is possible only with Paneling tools from Rhino
nice! looking forward for your update
i used various tools to create the voronoi structure and finally used MoI to model the eggs, so no paneling
with Rhino etc.
Voronoi.v.0.98
http://moi.maxsm.net/item/48
French version! ;)
http://moiscript.weebly.com/scripts-de-max-smirnov.html
Thanks a lot Max !
Thanks Max
Always funny!
how???
Very very nice!
<< how???
_Voronoi
Extrude "Tapered"
Flow on a Sphere
Render in free Real Time SimLab Composer Lite (max 1920 * 1080)
Have fun!
Here Corners of Voronoi are >90 so rounded (put 0 if you want sharp forms)
Voronoi.v.1.0.2018.03.05
Changed random algorithm.
Fixed bugs.
Thank you very much for your constant developing!!
Voronoi script is a extremely useful tools to create very different kinds of geometric CG!
I'm experimenting some cool stuff with Moi + Voronoi and iPad Pro.
Thanks.
With the new _Voronoi by Max Smirnov:)
Take 2 sets and use the ISect Boolean Function! ( whith Union Sets disabled )
then ExplodeMove hidden function
Have fun!
Here twice the same but you can take any things! :)
PS French Version Updated!
thanks!
Hello Max and everyone.
I had some fun with your Voronoi and the iPad Pro (Affinity Photo, PixelMator, Procreate 4, Snapseed).
Ciao!
Marco (mkdm)
almost perfect! the last issue is sharp corners even when smooth is 100%
5-24
25-44
45-64
65-84
85-104
105-124
125-144
185-198
