Full Version: Voronoi Script or plugin
Show messages:  1-20  …  121-140  141-160  161-180  181-198
5 Jan 2020   [#181] In reply to [#180]
Thank Michael, I'm going to have a look at it , I just rarely like to leave MOI3d , everything is very convenient there.
5 Jan 2020   [#182]
Seems you can make some 3D voronoi with only 2D ones ;)
i don't remember How I made that: a moment of inspiration! :D
9 Jan 2020   [#183]
Hi Roni,
I did with my friend Jotero lot's of 3D Voronoi Volume Mesh stuff in the past.
I am not aware of any tools for MoI that allows you 3D Voronoi points sampling
to obtain surfaces from them.
However, I attach a small tutorial (in German language) so that you can see
how one can do it with freely availabe Polygon Mesh Tools.
Please Note: the mentioned GTKRemesher, for obtaining excellent triangular
meshes is no longer available, you need to search the web to obtain a similar tools.
Best regards
VoronoiVolumeMesh.pdf
9 Jan 2020   [#184]
Another option would be to try to get the tool "GEEX",
which was once available from a French researcher in
this field. GEEX must be compiled and runs only under
Windows.
9 Jan 2020   [#185]
Does the Jotero forum always existing ?
9 Jan 2020   [#186]
Just find this free tool online :)
Result is in PLY so use MeshLab for convert it !:
https://www.voronator.com
9 Jan 2020   [#187] In reply to [#186]
as I remember also Blender can make 3D Voronoi.
10 Jan 2020   [#188]
@Pilou, the forum no longer exists.
@Rudl, yes, you can do also Voronoi stuff with Blender, however to obtain excellent results,
like a Centroidal Voronoi Tessellation (CVT), you need tools like GEEX etc. to sample the points set properly.
Blender can't do this and the results looks therefore not good.
P.S. See for example my Voronoi Eggs, I did once in MoI, at my Behance gallery, which use also CVT.
10 Jan 2020   [#189]
Meshmixer is able to do 3d voronoi shapes.
Skip to 8:40 in this video:
https://www.youtube.com/watch?v=kh5jKgsEQak
10 Jan 2020   [#190]
Inside free Wings3D also ;)
Special "Manifold" version! (there also many cool functions in these extension !
https://www.dropbox.com/sh/3cwsi5kvm0jeiae/AACWabcUIFe8UObZoyOvSQ6Ca?dl=0
Message 7177.191 was deleted
15 May 2021   [#192]
Hi Max,
I hope that you are well!
Because I do not find the 'ping Max' thread, even after searching, anymore,
I would like to ask you, in case you have time and like to do so, if it would
be possible to allow users also to create a Delaunay triangulation, besides
a Voronoi Diagram, with your superb script?
Best regards
15 May 2021   [#193] In reply to [#192]
you have this one ?
https://moiscript.weebly.com/objects2.html#delaunay
Here random points but i suppose you can input of course your own points ! ;)
15 May 2021   [#194]
It's me or the Voronoi plugin has not "Line, Polygon Curve" Working ? Only "Line" is enablelable!
EDIT i have an old one! :)
16 May 2021   [#195]
thanks, but I like to have that like Max's script and do not want
to use NodeEditor for surfaces etc. and only like to use 2D line art.
16 May 2021   [#196] In reply to [#192]
@Futugoza
Maybe this can help you ?
Here Proof's Points was drawn by hand (copy/Move) not by the Elephant nodal system by Max Smirnov!
Triangulation is drawn by the Elephant! :)
16 May 2021   [#197]
Great Pilou,
thanks a lot!
16 May 2021   [#198]
For someone who ask how i made that :)
You can use the last plugin of Max Smirnov
http://moi.maxsm.net/files/scripts/Voronoi.v.1.11.2018.03.09.zip
or maybe also the Elephant with some regulates :)
