Full Version: Voronoi Script or plugin
Show messages:  1-12  …  73-92  93-112  113-132  133-152  153-172  173-192  193-198
Message 7177.133 was deleted
9 Mar 2018   [#134]
French Version Updated! :)
http://moiscript.weebly.com/scripts-de-max-smirnov.html
9 Mar 2018   [#135]
Hi Max,
i just tested the new version, amazing!
(Did a quick PayPal donation. :-))
Best regards
9 Mar 2018   [#136] In reply to [#135]
Hi Stefan
Thank you! :)
9 Mar 2018   [#137]
Hi Max,
I have to thank you...!!!
I think i have some ideas, inspired by Pilou's recent image (the spiral),
for some new doodles. :-)
Best regards
9 Mar 2018   [#138] In reply to [#131]
This is the only word that comes to mind :)
A big thank to you Max!!
9 Mar 2018   [#139]
Hello everyone!
Thanks you very much Michael and Max for what you're doing ;)
Inspired and intrigued by the works of Stefan I had some fun with new Voronoi and some points :)
Check this video : http://take.ms/WOrWI
And this is the 3dm file is you want to play with it : http://take.ms/QKKdM
Ciao!
Marco (mkdm)
9 Mar 2018   [#140]
P.S...forgot to mention...
Clearly I was inspired also by the latest experiments of Pilou!
10 Mar 2018   [#141] In reply to [#139]
Very cool Marco!
On your various curve shapes...how are you going from control points to the individual points on the curve/path to create the Voronoi? As I experiment, I only get control points for the path. I "rebuild" the curve with # of points but I still get connected control points on a given curve/path.
Thx.
10 Mar 2018   [#142] In reply to [#131]
Amazing update as usual Max! Thanks!
Question though...
In the updated Voronoi.v.1.11.2018.03.09 script...is there a way to create a Voronoi without having an outside edge/border automatically generated?
Would be nice to have a checkbox option for border/no border. The older Voronoi script from 2015 didn't generate a border if I recall...which was great for certain things.
Screen Shot A (from 2015 Voronoi script) > Open outside border Voronoi is what I'm looking to do with the 2018 script.
Screen Shot B > Individual cells created from running Voronoi script...which creates outside square border.
Screen Shot C > After using the "separate" function to break the cells down to delete the outside square edges...makes a mess with all the duplicate curves from each cell to get an open edge Voronoi.
Thx!
10 Mar 2018   [#143] In reply to [#142]
just fun with Voronoi > blendcap > flow and Keyshot
10 Mar 2018   [#144] In reply to [#141]
Hi mat,
One way to do this is to create one point object on the curve (anywhere on a closed curve or at one end of an open curve) using Draw curve > More > Pt and then select the point you just created and replicate it along the curve using Transform > Array > Curve.
10 Mar 2018   [#145]
Exported to Modo and used mesh-ops to bevel and convert to quads for Catmul-Clark sub-division.
10 Mar 2018   [#146] In reply to [#144]
Cool Marco, Finema and danperk!
> One way to do this is to create one point object on the curve (anywhere on a closed curve or at one end of an open curve) using > Draw curve > More > Pt and then select the point you just created and replicate it along the curve using Transform > Array > > > Curve.
Oh Michael, i think you opened up tons of possibilities for us now, with this cool tip... :-)
I just used this for a Voronoi Text example were i increased the points to get a nicer text pattern.
Combining this now with extrusions and NSided caps and later bringing it into ZBrush, for
example, should bring up lot of cool things not seen before, when it comes to 3D text models
renderings... :-)
10 Mar 2018   [#147]
I mean something like this, not finished of course.
But IMHO the pattern looks now nicer, because of the evenly
spaced denser points.
Bildschirmfoto_2018-03-10_um_22.43.12
10 Mar 2018   [#148]
A new font! :)
10 Mar 2018   [#149]
He he, yes this could be an interesting field to be more explored...
But i think when i do this i have to much geometry with caps etc., for my little iMac.
So i do now first tests with math related doodles, without caps, to keep the polygon count low in MoI.
10 Mar 2018   [#150]
I've noticed that pre-selected points do not have to be in the z = 0 plane.
The voronoi script seems to ignore the z values (?) of the points, and treat them as if they were in the z = 0 plane.
10 Mar 2018   [#151] In reply to [#144]
Works great!
Thanks Michael!
11 Mar 2018   [#152]
My first math related Voronoi doodle with Max's script and Michael's tip, a Fermat spiral.
voronoi_spiral
