62-81
82-101
102-121
122-141
142-161
162-181
182-198
For leaves or fish's bones :)
WOW !!!! Super coooool!!!!
Thanks!
Hello Max!
@You : "...Thank you Marco, but I think it is not a good idea :) The current amount of thanks is enough for me, so we don't need to create a separate thread. ;).."
OK Max :)
Thank you very much for all your amazing plugins!!
Hi Max
>>I don't know when. I have a plan to add a couple of new powerful features. It will be more important improvement than adding of voronoi node.
Maybe after that I'll add voronoi node.<<
good sound for me , are your words
what else to say ...
good work and we hope to meet soon
Voronoi Node
have a nice day
alberto
Thank you Max:-)
Message 7177.127 was deleted
Hi Max,
i tried your script (old version) under OS X with 5000 points but i don't get the desired result.
For comparison i attach pictures from Adrian Secord's Weighted Voronoi Stippler (2) and MoI (1) script output.
I used his points output for x,y and added with sed z = 0.0000000 coordinates.
Attached is also the points file.
me.txt
O.k. scaled now with factor 100, much better, but still not there.
Maybe i have to try MoI v4 with your latest version.
Hi Stefan
forget about the first version :)
Latest version uses different algorithm and it works much better.
Also it works fine with both MoI 3.0 and 4.0.
Voronoi.v.1.11.2018.03.09
Made some performance improvement (thanks to Stefan)
http://moi.maxsm.net/item/48
WOW Max,
thanks a lot! I will then use your new version immediately! :-)
Best regards
Message 7177.133 was deleted
French Version Updated! :)
http://moiscript.weebly.com/scripts-de-max-smirnov.html
Hi Max,
i just tested the new version, amazing!
(Did a quick PayPal donation. :-))
Best regards
Hi Stefan
Thank you! :)
Hi Max,
I have to thank you...!!!
I think i have some ideas, inspired by Pilou's recent image (the spiral),
for some new doodles. :-)
Best regards
This is the only word that comes to mind :)
A big thank to you Max!!
Hello everyone!
Thanks you very much Michael and Max for what you're doing ;)
Inspired and intrigued by the works of Stefan I had some fun with new Voronoi and some points :)
Check this video :
http://take.ms/WOrWI
And this is the 3dm file is you want to play with it :
http://take.ms/QKKdM
Ciao!
Marco (mkdm)
P.S...forgot to mention...
Clearly I was inspired also by the latest experiments of Pilou!
Very cool Marco!
On your various curve shapes...how are you going from control points to the individual points on the curve/path to create the Voronoi? As I experiment, I only get control points for the path. I "rebuild" the curve with # of points but I still get connected control points on a given curve/path.
Thx.
62-81
82-101
102-121
122-141
142-161
162-181
182-198
