Full Version: Voronoi Script or plugin
Show messages:  1-12  …  53-72  73-92  93-112  113-132  133-152  153-172  173-192  193-198
8 Mar 2018   [#113]
Thanks Max!
8 Mar 2018   [#114]
With the little trick above :) http://moi3d.com/forum/index.php?webtag=MOI&msg=7177.81
(2 different grids Isected then ExplodeMoved: one with Corners =0, other Corners = 100 )
PS Subdiv (not applied here) don't works with all volumes ( surely some > 5 polygons! )
8 Mar 2018   [#115] In reply to [#114]
Very nice!
A sort of "fragments of an exploded planets" :)
8 Mar 2018   [#116]
Is it possible to add a file of points, as input to the voronoi script?
9 Mar 2018   [#117] In reply to [#116]
Hi Brian
you can use ImportPointFile script (http://kyticka.webzdarma.cz/3d/moi/#ImportPointFile)
then select points and run voronoi script
9 Mar 2018   [#118]
Hi Max
Thanks for all
some hope of having Voronoi tool in Nodeeditor ....
alberto
9 Mar 2018   [#119] In reply to [#117]
Hi Max.
Wanderul!!!
I wasn't aware of this opportunity!
Good to know. Thanks.
9 Mar 2018   [#120]
<< select points and run voronoi script
So... :)
9 Mar 2018   [#121]
Alberto
I don't know when. I have a plan to add a couple of new powerful features. It will be more important improvement than adding of voronoi node.
Maybe after that I'll add voronoi node.
Marco
>>The new thread I wanted to create should be : "PUBLIC THANKS TO MAX SMIRNOV FOR ALL HIS AMAZING AND PRICELESS JOB!!!"
Thank you Marco, but I think it is not a good idea :) The current amount of thanks is enough for me, so we don't need to create a separate thread. ;)
9 Mar 2018   [#122]
For leaves or fish's bones :)
9 Mar 2018   [#123] In reply to [#120]
WOW !!!! Super coooool!!!!
Thanks!
9 Mar 2018   [#124] In reply to [#121]
Hello Max!
@You : "...Thank you Marco, but I think it is not a good idea :) The current amount of thanks is enough for me, so we don't need to create a separate thread. ;).."
OK Max :)
Thank you very much for all your amazing plugins!!
9 Mar 2018   [#125]
Hi Max
Maybe after that I'll add voronoi node.<<
good sound for me , are your words
what else to say ...
good work and we hope to meet soon
Voronoi Node
have a nice day
alberto
9 Mar 2018   [#126] In reply to [#117]
Thank you Max:-)
Message 7177.127 was deleted
9 Mar 2018   [#128] In reply to [#126]
Hi Max,
i tried your script (old version) under OS X with 5000 points but i don't get the desired result.
For comparison i attach pictures from Adrian Secord's Weighted Voronoi Stippler (2) and MoI (1) script output.
I used his points output for x,y and added with sed z = 0.0000000 coordinates.
Attached is also the points file.
me.txt
9 Mar 2018   [#129]
O.k. scaled now with factor 100, much better, but still not there.
Maybe i have to try MoI v4 with your latest version.
9 Mar 2018   [#130] In reply to [#129]
Hi Stefan
forget about the first version :)
Latest version uses different algorithm and it works much better.
Also it works fine with both MoI 3.0 and 4.0.
9 Mar 2018   [#131]
Voronoi.v.1.11.2018.03.09
Made some performance improvement (thanks to Stefan)
http://moi.maxsm.net/item/48
9 Mar 2018   [#132]
WOW Max,
thanks a lot! I will then use your new version immediately! :-)
Best regards
